Lemon R32 Gt-r
Hi Guys,
Apologies if this is in the wrong section...... I wasn't sure exactly where to post. I thought this would be a good starting point :)
I bought an R32 GT-R imported from Japan about 5 months ago thats a complete lemon. Its been mostly sitting in my garage, and that of a pannel beater who went out of business recently, waiting for various things to happen. Luckily, the guy in Japan that I bought it from is doing the right thing and helping me with getting it to an acceptable state.
I need some recommendations for workshops in Perth to do the rebuild on the engine, as well as the rust repairs.
Problems with the engine include:
Noisy valve train - noise is most evident when parked, in neutral, after warming up, gently reving the engine up to about the 4000rpm mark, a noise like a flapping heat shield seems to be coming from the rear drivers side of the engine. I've had a good look and there dosn't seem to be any loose bits that could be causing this noise. I've pulled the rocker covers off and all the bolts/nuts for the cams are all torqued up correctly. I've also checked the clearance between the cam lobes and the tops of the valves and they are mostly ok, however there are a couple that are about 2-3 times the tollerance out. I have doubts as to if this would be enough to cause this noise.
Cylinder 3 is as oily as anything.
Compression is all over the show:
Cyl1 - 160PSI
Cyl2 - 155PSI
Cyl3 - 170PSI
Cyl4 - 150PSI
Cyl5 - 135PSI
Cyl6 - 155PSI
4WD system dosn't work. (pretty open ended problem, I know)
Pannel beater who was originally going to do the work on my car before going out of business said that there was some noise from the bottom end.
Gearbox has a noisy bearing on the input shaft (i've sourced a recently rebuilt gearbox to solve this already).
On the rust side of things, there are rusted out holes right the way through the floorpan on both the drivers side and passenger side, front and rear where the jacking points are located. I suspect based on the fact that all the metal underside around these points is pushed up and deformed that the previous idiot owner in Japan has no clue about using a jack!
It seems at this stage that the guy I've bought the car from in Japan is looking to cover the cost of labour on the engine rebuild and I may have to either partially or completely cover the cost of parts.
At this stage, I'm not looking to spend a heap on the engine internals. I simply can't afford to currently.
I'm guessing that as far as the engine rebuild goes, I'm up for a full set of bearings, valve guides, rings, potentially valve springs, gaskets, timing belt, other belts, hoses etc and other incidental bits during a rebuild. I'm also thinking that it may be a good idea to put an uprated oil pump in place as I've heard many times about the oil pumps on the r32 GTRs shitting themselves. Nengun have a Trust oil pump for $1200. Are there any other relatively inexpensive things I should do to the engine at this point in time to make it more reliable, or able to handle more power?
I'd really appreciate any recommendations that anyone can give me on local workshops in Perth to do the engine rebuild (or workshops to avoid for that matter), or pannel beaters to fix the rust (and likewise to be avoided).
Cheers,
-Shaun
Aren't there rules under the current compliancing system preventing rust repaired vehicles from being passed:(
yeah but how many come through rusted to the sh!thouse, then bodge-fixed and on sold by unscupulous dealers?
Damage control in maddington for panel repair work are about the best i have heard of for skylines and Top Racing in bentley for mechanical side of things theyare both in phone book ( steve at top racing is a gtr guru)
I see another who has jumped onto the the cheap gtr bandwagon and been burnt.
I always tell people don't spend all your money on a 15 yo car and not save any for repairs. Cheap cars are espcially bad - you get what you pay for.
Now, to fix it - having to rebuild the motor is probably not a bad thing. just like with any other 32, most of them are f**ked. so at least you'll be guaranteed a good motor.
Also, most of the 32s i've seen haev a bit of rust, especially the ones from the north. if it's not too bad, then repair it.
All in all, it sounds like the car was really cheap, so even after repairing it, you will probably still end up pretty well off.
2-3 times the tollerance out!?
RB26 valve clearence is quite large to begin with - ex .38mm (.015") , in .45mm. (.0177")
If your clearences were 2-3 times this it would sound like a diesel!
post up what you actually measured....
You dont need a $1200 oil pump unless you are chasing big power/ high rpm.
Just get your r32 crank modified using a collar that has a wider oil pump drive on it. (proengines from here makes them) and use a r33 oil pump or an N1 pump.
Good luck with ya rebuild
Hi All,
Thanks for your replies...
Thanks gazza750... I'll give them both a call on monday and have a chat.
Yup. However, the vehicle wasn't cheap... it was just shy of $16,000 australian before import duty, ompliance etc etc. Based on the photos and the description, allegedly 60,000km, seemingly genuine, supported in every way by the rest of the description and photos etc, I assumed I'd managed to score something really worth having. However, it turns out not to be. This vehicle was several thousand more than the other vehicles available at the time, all of which had more realistic milage of anywhere from 100-160,000. I suspect mine was at 160,000km (doing hard miles at that) and the odometer was simply wound back.
Genuine Nissan GTR N1 Oil Pump Price: $499
Upgrade oil pump for RB26DETT
JustJap.com
Thanks Mr Italy!... Sounds like this one is the go-er then :D
Thanks CSRB25DE. Unfortunately I took the measurements about a month ago and never recorded them. So this is the likely the cause of the noise I'm hearing.
I guess the moral of this story is never buy a car sight unseen, especially if its in another country.
Does anyone have any more workshops or pannel beaters to recommend?
Cheers!
-Shaun
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
