my car has bad picked up a pinging when it goes past 4500RPM
I use BP ultimate in it, i have had it to a local workshop who had it all day and said it will have to go back when they can figure out what is causing it
They believe if anything it may be an aftermarket 02 sensor that isn't working with the standard ECU, anyone got any other ideas what may be happening as it started it out of the blue one day while driving to work.
https://www.sau.com.au/forums/topic/119787-pinging-at-4500rpm/
nah i haven't done anything to it yet. As far as i was concerned when i bought it, it was all stock standard except the HKS airfilter now i find out it has a aftermarket turbo dump and oxygen sensor. they checked all the mixtures and said that they were all correct
could be a bad batch of fuel. try some good octane boost like nulon pro strength. if that solves it then wait and see if it still does it on the next tank of fuel. if it still does it then get it looked it, if it doesn't come back even after a few more tanks of fuel then it was just a bad batch. and make sure you don't put too much octane boost in as it can actually lower the octane.
mate of mine is a mechanic and he had the nulon rep come through work and he was asking him about the octane boost. the rep had an octane tester with him so they did some tests. at 50% strength it went by only about 2ron, at full strenght it went up by 6ron, and at double strength it dropped by 4ron.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
