You will need to get off the crank pulley, i've always used a pulley puller and just be gentle getting it off :)
The whole timing belt comes off and you can check its condition/replace it. Make sure you have all the alignment marks (crank and cams) aligned before reassembly with the timing belt. Adjust the tension, and tighten the belt tensioner nuts to specific torque (around 50nm from memory, crank pulley (150nm).
There is plently of threads, try searching for timing belt replacements, you need to do everything involved with changing the timing belt.
Oh and make sure you reseal the water pump very well to the block, water leaks through smaller holes than oil and you don't want it to leak once it's all back together.
Cheers
https://www.sau.com.au/forums/topic/119811-water-pump/#findComment-2207374
you'll only need to take all of your belts off.
you could get away with keeping your timing belt on if you're REALLY careful.
just undo the screws (remember which screw goes where), scrape off the old gasket off both surfaces, make sure theyre nice and clean too.
get the new pump and put the new studs into it (if you dont know how, let me know and i'll type it all up for you).
slap on some gasket maker on it and screw it on.
a few things to remember:
- be careful when taking off your fan, its a prick of a job in the position its in.
- REMEMBER which side the water pump pully is facing, last thing you want is to put it on the wrong way.
https://www.sau.com.au/forums/topic/119811-water-pump/#findComment-2207523
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
