First of all I have a S1 RB25DET in a 89 S13.
I was tinkering with it the other day then suddenly, it started to stumble and die. My gas light was on and the gas level was so low that it got stuck on the plastic cover. So I automatically assumed that I ran out of gas. No big deal.
I let it sit for a few days before trying to start it again. Now today, I filled maybe 2.5 gallons of gas into the car. As I went to start it, it didn't start. I tried numerous times.
Things I know:
- I have spark
- The fuel pump primes on "key on"
- After cranking, I checked plugs 1 and 2 and they were dry. No fuel on them. I was expecting them to be wet and fouled from all of the starting attempts
- The car ran perfectly before it died. I was setting timing and idle and it drove great at that time.
- I pulled the fuel pump out and the sock looked kinda dirty. I also noticed some rust flakes/dirt in the tank.
- The fuel pump and filter are brand new. Is it possible that the fuel pump sock or filter is clogged because I ran the gas so low causing it to pick up dirt at the bottom of the tank?
That's about all that I can think of right now. As I find out more information, I'll notify you guys. Thanks in advance for any help.
https://www.sau.com.au/forums/topic/119815-ran-out-of-gas-now-car-wont-start/
not very likely. maybe you just sucked the thing dry.
how much is 2.5 gallons? fill it right up (just in case if your tank can't suck to the bottom.
try and start it a couple more times so that the lines actually get some fuel in them. you should be right. i've done it a few times on various cars and they all recovered.
2.5 gallons is 9.46 liters. Sorry I'm from the US.
I've tried starting it lots of times. Maybe too many times at this point. My fuel pump was submerged in fuel when I pulled it out. I'm pretty positive that I'm lacking fuel and or fuel pressure. I don't smell fuel at all during cranking and the plugs stay dry. I'll have to check my fuel pressure to confirm this.
When you say the fuel filter is brand new, do you mean before or after you ran out of fuel? I would change it you have probably clogged it suckign the crap out of the bottom of the tank. wierd that you are not getting any fuel though
The fuel filter was new before I ran out of gas.
I just realized that I might have another issue. I didn't have my fans on when I was setting timing and my idle speeds. And I think I remembered seeing my water temp gauge hit "H". So I'm sure I was overheating and running out of fuel at the same time. I had the car idling at the time. Can overheating at idle cause my car not to start? I didn't notice any audible knock, boiling coolant, or anything out of the ordinary.
well start with a new filter.
Its very unlikely you cooked the motor causing to not start, not impossible but you would have to be pretty unlucky.
Remember all you need to start the motor is fuel, spark and compression......unlikely to be compression but you can always test it.
Found the problem!
First I checked to see if I had fuel coming out of the feed and return lines off of the rail using the bottle and prime method. It turned out that I did have fuel going to the rail. But I swore that I wasn't getting fuel to the engine. So I disconnected the CAS to disable ignition and tried to start the car. I did this to see if my pugs would get soaked in fuel or not. Sure enough, there were dry. So right then and there I knew my problem was in the injectors. I originally bought the car as an unfinished project and I had to redo the wiring because I wasn't comfortable with crimp connections that the original owner used. I double checked my injector circuit and I found that there was an open in the injector power source (grey wire) where the original owner used a splice crimp thingy. So I closed the connection and bam she fired. So I guess I did run out of gas after all. Thanks for those who helped.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
