My car has HKS T3G fitted with an old HKS tube & fin FMIC. It runs APEXi ITC & AFC computers with standard ECU piggybacked.
An adjustable electronic Blitz boost controller keeps boost at 15psi all day.
With this set up it pulled 171kw at the wheels but pigning at high rpm when intake temps got up.
To be safe for track day Eatern Creek coming up, I fitted a rising rate adjustable fuel reg in case lack of fuel was causing pinging.
After re tuning on the dyno it pulled 200.5 kw @ rw.
Now i'm fitting water spray to keep intake temp down.
  • Replies 42
Geeze its taken me almost 3 weeks to convince myself to get new rear shocks ($700 fitted) instead of buying a fuel reg + adj cam gear.
Thats a nice increase from the fuel reg, obviously you had abit of a bottleneck there !
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
