I tried searching :D , and I read the FAQ on the powerfc which was very helpful, but it didn't answer my specific question...
I'm going to get a powerfc for my R32 GTS-4, and just wanted to know if the normal RB20 version (AP Engineering) is the one for me.
The ATTESSA has an independent computer under the parcel shelf in the boot, right? However, would the 4wd system also incorporate the use of the standard ecu for certain functions? I'm asking this because i'm wondering if the rb20 powerfc would take this into consideration if in fact the GTS-4 ecu is involved with making ATTESSA work.
Even though you can modify the rb26 powerfc to use with the rb20, apparently the only things that need to be modified have to do with injectors and not anything to do with ATTESSA in the rb26 version. Even so, i just wanted to know if the normal rb20 version will work fine with my gts4!
Any help would be great!
Thanks.
Edited by petgts4
https://www.sau.com.au/forums/topic/119862-powerfc-for-r32-gts-4/
Isn't the power fc a plug-and-play type unit, where you basically use the old ecu harness to plug straight into the power fc? Therefore the wires that also connect to the attessa ecu would remain the same because no wires would be modified, right?
Then you'd just get your car all tuned up...
Edited by petgts4
hey mate, the engine harness would have the wires intact but the ecu will have no pins for the 4wd wires as the ecu is meant for rwd rb20's.
its simple to hook up anyway once u find the correct wires.
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
