Ok guys I have plans for an R34 GT-T. J-spec has some for $25000 landed and complied (plus ive notcied one on here going or $25000!) As per normal it wont be left stock. Visualise a midnight purple R34 with 18" Starcorp Racing Impul Chromes (white with chrome lip and 18 by 9s on front and 18 by 10s on the rear). May or may not put on a URAS monkeykit. Mods are as follows:
- 3" cat-back zorst
- Trust FMIC
- Star Racing Impul Chromes (18 by 9"s and 18 by 10"s)
- HA coil-overs
- Nismo 2-way LSD
- Trust Td06-20G turbo
- 770cc injectors
- heavy duty clutch to support the new power
Now im a newbie when it comes to modding cars and have no idea about the costs involved so the flame suit is ready. If there are any parts that are needed that i havent mentioned yet please say so and the cost of the part. However, if someone would like to give me a rundown on the costs involved. I'm guessing about $3000 for paint job? $500 for zorst? $3000max for wheels? $1700 for HA Coils? $1100 for FMIC? and the rest im unsure about so any help will be appreciated. And as for how im gonna afford it, I'm employed by the Defence Force so its not really a problem.
https://www.sau.com.au/forums/topic/119893-project-r34/
wheels 1600
turbo back exhaust - 1200
turbo 2k maybe?
injectors 1k
fuel pump - 250-350
power fc - 1k
boost controller - $35 - $600
air filter - 100
FMIC - 500 - 1000
tuning 5-6hundred
new clutch - wouldn't hav ea clue how much
6-7k in engine mods alone
then there;s the suspension
Coilovers - 1.5-2.5k
thats a lot of money so I'd save that useless paint job $$$ and use it on the engine
unless you just wanna look good
https://www.sau.com.au/forums/topic/119893-project-r34/#findComment-2208532
770cc injectors ehh? There's about $1500 worth of gear already :cheers:
I also don't think the Starcorp rims come in 18x9 and 18x10... even if they did, they would look ridiculously stupid as the wheels would come out of the guard. I have the 18x8.5 and 18x9.5 and they are already borderline.
What about boost control? Don't tell me you're planning on running a stock setting for such a large turbine?
And all those little bits and pieces? They all add up there too...
I agree with James, save the 5-6k from the paint job, and get the mechanicals all right first... at the moment it just seems like you want a bit of everything (Autosalon entry?)
https://www.sau.com.au/forums/topic/119893-project-r34/#findComment-2208690
- 3" cat-back zorst
- Trust FMIC
- HA coil-overs
- Nismo 2-way LSD
- 770cc injectors
It will look hot when its finished will cost you though. As above you will need upgrade Fuel system, ECU, boost control, AFM, clutch, ECT check out the tuning guide in my sig it may help
cheers
https://www.sau.com.au/forums/topic/119893-project-r34/#findComment-2209224
my advice would be -
1. buy the car
2. drive the car for a while
3. start to think about mods
its all pretty hypothetical at the moment, especially seeing as though you're only just thinking about importing now. have a look (search button) around here at what other people have done, should help you get things a bit clearer in your mind
https://www.sau.com.au/forums/topic/119893-project-r34/#findComment-2209244
You do realise it is a major defect to have 18x9" rims on the front? You are only allowed 8" wide rims on the front by law (I think that is an ADR requirement). There is no point in 18x9" really because if you are going to go wider than a 245 tyre (which is about the widest you can get on an 8" rim), then you will probably have problems with rubbing on the inner guards at full lock. I would stick with 18x8" on the front with 235 tyres.
https://www.sau.com.au/forums/topic/119893-project-r34/#findComment-2209388
