Hey guyz,
As what mentioned in the topic, I'm after two 225/35 tyres and willing to pay $150 for them, which I don't really care what brand they are, as long as they have about 60% thread as they will be used for RWC. Also has to be in Melbourne as Postage will cost.
Thanks!
John.
https://www.sau.com.au/forums/topic/119903-wtb-2-x-18-tyres-22535/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
