Car is a 89 S13 engine is a Series 1 RB25DET.
For some odd reason my car runs like crap on stock timing. There's just no power up top and it feels really rough. It makes lots of noise but doesn't really go anywhere. But when I set timing closer to 20* BTDC, it feels much better. It has more power and it comes on a lot smoother up top and down low. I know for a 5spd RB25 stock timing is 15* and for an auto stock timing is 20*. But my engine is a 5spd manual. I'm really stumped with this and I don't want to ruin my motor by running incorrect timing. Has anyone had an issue like his before? Any help is appreciated.
Is that +6 degrees over stock timing (21* BTDC). How modded is your engine?
how are you checking your timing? is it possible that you have infact been moving the timing the other way and dropping it to 10*btdc?
also what fuel do you run? if it is crap fuel then that may be the cause. set it back to 15* and put some good octane boost in and drive it round for a bit and see if that makes it run any better.
I'm checking timing with a Snap On timing gun using FSM procedures.
When I was setting timing to 15*, I aimed for the 4th mark from the left on the crank pulley.
For example: l l l l <---This one
0* 5* 10* 15*
I'm running 93 octane fuel (highest grade available here). I'll try octane booster to see if that makes a difference or not at 15* BTDC.
I just went back out for a quick drive. I don't really want to drive too much b/c of my lack of fans. But I noticed that at 15*,17*, and 20* my car felt slow. It honestly felt more sluggish than a stock KA24DE. So in desperation, I rotated the CAS completely counter clockwise (advanced) and went for another drive. It felt great - like a 6 cylinder turbo should. Albeit it wasn't too smooth due to some ignition misfires but it actually felt fast and it knocked my head into the seat. None of this occured at close to stock timing. I'll have to wait to get some fans on before I got out for joy rides again. I don't think I've been doing my engine any good running w/o fans.
One of the things I notice with guys new to RB’s is they tend to point the timing light vertically, straight down at the timing mark on the cam cover. This is wrong, the timing light needs to be 25-30 degrees off vertical, towards the airfilter, (the RHS looking at the engine). If you point the timing light vertically you see about 5 to 8 degrees advanced from where the timing really is. Move the light (and your head) across to the right and you get a better indicator of the real timing.
:) cheers :)
I'm new to RB's but I'm not new to Nissans and timing them in general. Also, I'm a techinician for Honda.
I'm definitely pointing the gun correctly. I also learned that it's easiet from the right hand side. The timing indicator is also easier to see from that angle.
Edited by 240dreams
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
