Car is a 89 S13 engine is a Series 1 RB25DET.
For some odd reason my car runs like crap on stock timing. There's just no power up top and it feels really rough. It makes lots of noise but doesn't really go anywhere. But when I set timing closer to 20* BTDC, it feels much better. It has more power and it comes on a lot smoother up top and down low. I know for a 5spd RB25 stock timing is 15* and for an auto stock timing is 20*. But my engine is a 5spd manual. I'm really stumped with this and I don't want to ruin my motor by running incorrect timing. Has anyone had an issue like his before? Any help is appreciated.
Is that +6 degrees over stock timing (21* BTDC). How modded is your engine?
how are you checking your timing? is it possible that you have infact been moving the timing the other way and dropping it to 10*btdc?
also what fuel do you run? if it is crap fuel then that may be the cause. set it back to 15* and put some good octane boost in and drive it round for a bit and see if that makes it run any better.
I'm checking timing with a Snap On timing gun using FSM procedures.
When I was setting timing to 15*, I aimed for the 4th mark from the left on the crank pulley.
For example: l l l l <---This one
0* 5* 10* 15*
I'm running 93 octane fuel (highest grade available here). I'll try octane booster to see if that makes a difference or not at 15* BTDC.
I just went back out for a quick drive. I don't really want to drive too much b/c of my lack of fans. But I noticed that at 15*,17*, and 20* my car felt slow. It honestly felt more sluggish than a stock KA24DE. So in desperation, I rotated the CAS completely counter clockwise (advanced) and went for another drive. It felt great - like a 6 cylinder turbo should. Albeit it wasn't too smooth due to some ignition misfires but it actually felt fast and it knocked my head into the seat. None of this occured at close to stock timing. I'll have to wait to get some fans on before I got out for joy rides again. I don't think I've been doing my engine any good running w/o fans.
One of the things I notice with guys new to RB’s is they tend to point the timing light vertically, straight down at the timing mark on the cam cover. This is wrong, the timing light needs to be 25-30 degrees off vertical, towards the airfilter, (the RHS looking at the engine). If you point the timing light vertically you see about 5 to 8 degrees advanced from where the timing really is. Move the light (and your head) across to the right and you get a better indicator of the real timing.
:) cheers :)
I'm new to RB's but I'm not new to Nissans and timing them in general. Also, I'm a techinician for Honda.
I'm definitely pointing the gun correctly. I also learned that it's easiet from the right hand side. The timing indicator is also easier to see from that angle.
Edited by 240dreams
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
