Hey skyliners,
I have a small amount of oil that has come out of the top of the engine where the kinda square U-shaped hose goes from one side of engine to the other. Is this really bad? When looking at engine from front, the right side is a bit dirty, and I remember trying to clean it before, so it's coming out still...
Is this a part that should be changed? I guess being a rubber part on an old girl ( '93 R33 @200k) it might be time for a change soon..?!
Should I go down to autobarn and get a new one? and are there other ones I should change?
thanks..
https://www.sau.com.au/forums/topic/119935-time-to-change-oil-hoses/
If it's the one that goes out the top of the RB I *think* that's the oil blow by - in which case if you have a healthy engine you shouldn't have any coming through.
It is there to catch any that does though so it might not be bad. I'd just clean it up, replace it and get a catch can - after a while see if you have lots of gunk going into the catch can. If you do then you can decide if you'd like to find the problem or drive your car till it dies.
Ignore my post if the oil blow by pipe isn't what it is.
Thanks for that. when i changed my spark plugs today I found that bth sides of the hose had split! There was a bit of oil to clean up, so off to autobarn to get new hoses tomorrow. I'm going to replace everything I can. Once I have a bit of spare cash I might look at a catch can.
cheers
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
