  • Replies 47
Well anyway back on topic...
Who does the tuning at BD4s, is it Tom or the other guy?
I just found out from my HK buddies that to get the HKS gear tuned it costs them almost $5,000AUD
They get some guy from Jun in Japan to fly over and do the tuning... imagine if that was the same here :(
Jim at CRD tuned my car, I found that the car had more torque off boost and less black soot build up on my rear bar compared to the previous road tune.
The car started pinging after about a 2 weeks (bad fuel?) and Jim spent about half an hour retuning it - at no cost – and it hasn’t pinged since.
I haven’t been to BD4’s
Pity your car wasnt ready to tune a few weeks ago Stan.
Just Jap had the owner of Autech Japan out here and he is an F-CON tuning guru.
...The car started pinging after about a 2 weeks (bad fuel?) and Jim spent about half an hour retuning it - at no cost – and it hasn’t pinged since....
now here's the question.
Was it bad fuel or a bad tune in the first place?
If it was just one batch of bad fuel, couldn't you put it back to the earlier/ better tune once you put new fuel in? Or was it tuned without sufficent margin for safety on the road, taking into account variable fuel, hot days etc.
Did you get a dyno graph from the first tune? what were the AFRs? How much base timing?
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
