Initial D : The Arcade Stage
Guest crunchychewynutz
Hey guys, anyone here tried the Initial D Arcade Stage game? I think its pretty cool to be able to drive customized crs and save the settings and mods for later games.
I got myself a Skyline BNR 34 with the C-West Bodykit and Mines Exhaust. What a blast!
Come forward with you cars and mods and driving tactics here!
https://www.sau.com.au/forums/topic/11994-initial-d-the-arcade-stage/
http://www.segarosso.co.jp/INITIALD/
The link to the game details are there! The cars and their mods are listed there, and theres a link to quite a few Jap tuner companies too.
I guess the Japs ran it ragged before we even got a whiff of it in Singapore!
The memory card concept is the next big thing in arcade gaming!
Lol, I've got about 15 cars to the end, too much time working at town hall lately.
mrs was hardest to get to the end, and EG6 civic. mx5 also sucked. Surprise car was type r integra, its been the fastest on the final track by a long way.
I did, in a Suzuki Cappucino! The little car takes the hairpins at 140++ kph! I beat him with a comfortable lead of 200 plus meters!
My RX-7 and Skyline can't take the hairpins well, and if you let Bunta take the lead, you're done for! That WRX will just pull away from you!
The Cappucino is available in Initial D : AS Version 2!
In this new version there's the new Lexus IS200, RX-7 Spirit R, and many more cars, as well as new mods for existing cars. new tracks too, the last track has about 15 hairpins (Integra is the car to beat here, in terms of sheer cornering speeds).
The new C-West mod for the R34 is da bomb!
  • 4 weeks later...
  • 3 weeks later...
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
