Was you old Group 3 a VH / VK /VL?
I've always been a bit partial to the VH group 3, and wouldn't mind if I had one with the HO pack sitting in the back shed :wink:
I'll be a cop out and say all my cars have been the best - I liked them all.
1978 XC Fairmont (219kw), 1982 XE ESP (stock as a rock 302), 1989 GTS-t, and my current R33 25T. Next car? Hmmm. Oh the options.
My R33 4 door is the latest evolution in Nissan cars. 1st car was a datsun 1600, Datsun Stanza, Honda s600( I know,but it was so cute),Datsun 1967 Fairlady 2000 High Screen sports convertible ( looks like MGB only much nicer), datsun 120Y and now Skyline R33.
Dont have to coerse the car 2 start each morning :P
  • 6 years later...
for some reason.. my old 78 golf was the most fun car i've ever owned, sunroofs are sick, and so was 4wding n throwing it thru mud.. POS cars are so much more fun than fast cars.. have got a 32 gtr and a 69 pacer, had a 32 gtst, ta22 celica, 81 corolla.. golf is only car i'd ever want back.. was so damn sick.. jesus this threads older than me ;o
Edited by GTAAAH
LOL someone already asked the question you had planned on asking terry? So your like only.. 6yrs too late :P
LOLz LMAO HAHA
Yeh I was digging around in the dirt, and look what I found? THIS OLD THREAD!!!
I had fun looking at the earlier posts tho'
...trust you Craig to scrounge around and sniff it out... lol
I rate cars as I do many things, on value for money so far an old hyundai excel I paid $700 for with 12 months rego and free rust that gave me many years of service free, hassle free motoring wins!
Dont really like my whale....its too heavy and too slow, but it was cheap and nasty so It'll do!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
