I just bought an 040 to replace my fuel pump and have some questions about the install.
I know you cut the bottom of the standard bracket and clamp the pump to the side of the existing bracket with rubber inbetween to stop vibration. What I need to know is:
do you need to use a filter with the 040 or is there a filter on the bottom of the pump underneath the mesh base?
will can the existing fuel line fit over the fitting on the 040 and then be clamped on or do I need a screw fitting of some type?
Can you get a pump assembly gasket from nissan? they said they only come in kits.
If someone would be kind enough to list a "what you need" list.
Also I spent 1/2 an hour digging thru "pump" bosch" 040" threads looking for a photo of one mounted on a bracket but couldn't find one and I was sure I had seen one here before.
thankyou!
sounds good. Did you need to use a new tank seal? and where do you get one.
also are the electrical contacts on the old pump the same? I just want to get everything I need before I pull the car apart.
You will need to find 2 nuts that fit over the 040 terminals
Then just need to solder on some connectors onto the standard wiring and secure them to the pump with the nuts
New tank seal is a good idea, Nissan should be able to source you one
Hi mate, good luck.
I had mine installed by the mechanics/tuners along with a lot of other gear at the same time, so I cant help much.
Two suggestions: a) I had them direct wire it to the battery feed, so it runs at ~13.8v and not 12v. b) I also made directions that the 040 pump MUST be installed as low in the tank as possible. That way I have no fuel issues, I can go down to near empty and be all ok.
Thanks Chris. I will buy the bits I need.
No Probs
Another thing I found helped, angle the return feed away from the pickup point, as with the higher volume pump, it causes cavitation in the fuel (air bubbles) due to much more fuel being pumped back than the stocker. You might have heard it on some cars with up-graded pumps, sound like the pump is sucking in air
I acutally trimmed my fuel return pipe and attached some fuel hose and angled it well away from the pickup point of the pump. The fuel returning is generally much warmer too.
Wiring it straight of the battery is also a good idea, you can do that later if you find the supply is not enough
I think Cubes did a DIY thingo about that
DO you need to wire directly from battery or will the 040 pump b ok off of the stock wiring. Will just not pump it's maximum pumping capcity when on stock wiring.
My guess with wiring off of the battery is that the ignition crontrolls the relay that switches the pump on throught the battery is that right?
Edited by Madtrang
It's a 12V pump, running it at 13.8 volts does not do anything except heat it up more. You need to cut the earth wire to the pump and direct earth it to the body in the boot somewhere. This removes the dropping resistor from the equation. The resistor is what drops pump speed when you come to idle.
Is that necessary. If your @ idle u dont need alot of fuel being pumped or are there other reasons why it's a good practise to ground it properly.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
