Hey guys,
Kind of silly n00b question, but im stuck, where do i begin modding my car,
Essentially i want the car to slide well (drift), but do i start with power or handeling?
The car is completely stock bar the front strut bar and a pod, should i go for exhaust or coilovers?
Any suggestions?
Cheers
(sorry for the n00b question........)
https://www.sau.com.au/forums/topic/120054-4-door-r32-gts-t-mods/
Good to hear. I have a 4 door gtst 32.
If you want to drift a good choice is the suspention. Coilovers all around.
front mont cooler and then you can up your boost a bit.
17" wheels are better than the standard for drift, they also look far better.
you also will need to lock/remove your HICAS (rear steering) because drifting will become hard with any speed.
Mal
Edited by wal
(sorry for the misplacement of topic.... may bad)
Thanks for the info, i was leaning toward suspension, i was planning on teins and a hicas lock kit, looks like that will be my next mod!
I guess in the early learning stages power isnt important its more about technique and set up.
Thanks man.
Yeah mate if you're heading for drift a set of coilovers with 8kg front, 6kg rear spring rates. Pretty good balance for a daily driver.
Make sure to get a Hicas lock BAR. As some kits only add washers to the hicas mechanism.
If you can handle a bare boot> Strip it bare.. There's a good 20-30 kgs kg's in there.
After the suspension is sorted you should really look at a good mechanical LSD. But if the stocker is in reasonable nick you could probably get away with it for a few months(cause I know stock exhausts suck). If you're really cheap you can get it 'Shimmed up'. But they rarely last more than a year after that.
That was another question i was going to ask was spring rates, thanks Drift limo!
Shimming up the diff sounds like it will cost more in the long run, what are your guys opinions on KAAZ diffs???
The lock bar is def going in, hicas is annoying :D
Should i be installing sway bars with the coils and camber arms?
Cheers guys
I have a R32 sedan which I use to compete with in Perth. The basic mods I started off with was a catback exhaust, pod filter, hicas lock, front and rear strut braces and a set of coilovers. Which I found was more than enough to start drifting on. Since then I have added pineapples, GTR skyline rear swaybar (enables slightly more oversteer), a cheap spring type boost controller and a FMIC. If I had my time again I would spend the money on buying a decent FMIC kit, preferably one which has 'switchback' piping (comes in at the right and goes back the same way) because it will for one allow you to put in a decent size oil cooler in a convinent location and also avoid the heatsoak that the piping recieves through the crossover piping (which pretty much render's the FMIC pointless).
There is no need for 17" rims or tyres. I drift on stock GTS-T rims 205/55R16's front and rear with the rears sets set to 45 psi. However if you already have them good grip front tyres are definately a necessity. Before you go drifting on the track remove your rear seat and spare tyre and then you should be able to fit 4 rims with tyres in the area where the back seat was with ease.
Having more power always helps.. but its pretty pointless if you can't use it effectively due to lack of driver skill or suspension setup. Stock power with a catback exhaust and a pod is more than enough to start off with. Allows you to drift with your foot flat as well most of the time which makes it easier to drift on.
So in your position I would say lock the HICAS as a first priority then find some coilovers and then an exhaust. And this should be more than enough to get you started.
Oh yeah make sure your handbrake is adjusted properly as well.
Cheers,
Baz, this will sound wierd but ive sen you slide at wanneroo and your the reason i got a four door.
What youve just said makes mucha sense, looks like ill be doing that switchback idea too!
Thanks for the input guys, it will be put to good use!!!
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
