well, I noticed on cruise, boost, off boost, everything, my car is pouring black smoke.
Even with the AFR's running at 15.7:1. I'm going to assume the injector setup by my "mate" of a wanker tuner is set up incorrectly... (this guy really was a waste of money..)
I have just had a look at the Datalogit Settings, and it says that my injector size adjust is 77.0, and my lag time is 0.40.
Now, the datalogit says that to work it out:
Old Size Divided by the new size = Difference.
370cc / 555cc = 66.7% (the tuner has entered 77.0%...wtf?)
old lag time minus new lag time = final lag time.. The tuner has entered 0.40ms.. I want to see if this is stuffed up too..
I don't know the standard lag time for R33 injectors, can anyone help me?
Edited by The Mafia
I might be able to help but I am just learning this stuff myself.
From what I know the stock injectors have a lag time of 0.58ms. Google tells me that nismo 555cc injectors have a lag time of 0.71 ms but not sure if you have these. Best bet to ring nissan dealer and ask the question.
From what I understand, the injector lag column is the difference between stock and your new injectors so in your case should be (0.71-0.58) = +0.13ms, however you will notice that you can only select in increments of 4 or something so 0.12 is probably the best bet.
As for the injector trim calculation 370/555*100 = 66.7% is correct but be careful that your "tuner" hasnt also applied a 11% trim to each cell in your INJ settings.
Hope this helps.
The inj. correction really doesn't make any difference providing the base map has been tuned to suit, as Color_of_green has stated.
Its pretty much the same with lag time but it IS best to get the lag time right.
I'm curious as to how its pouring black smoke?
On idle? Under boost? Under quick heavy throttle?
Mine with a flat 12:1 afr still trickles a little black smoke on wot, it can especially be seen at night time in the head lights of the dissapearing car behind. :(
If its dropping a puff here or there look at the accel enrichment. I believe with the pfc you are able to reduce the sensitivity of the accel enrichment which 'MAY' pick up a little fuel economy as it doesn't drop out of closed loop as easy. I know with mine it is very sensitive to throttle input, the slightest little quick flick of the throttle and it drops out of closed loop.
i don't know about the 550's but the difference between stock sr (which are the same as rb25 anyway) and nismo 740's is only about .02ms i think (it's been a while since i set it up)
The difference between my stockers and my 550 single pintle (laggy) injectors is only .12 from memory.
I'll dig up my apex engineering sheets when i get home and check. Are you sure the lag isn't .04, .40 is way off?
Sorry Mafia dude, since we are on the topic i'd like to ask a few too..
So just say that the tuner has inputted wrong settings for the injectors and went ahead
to tune the whole thing. Once you change the settings afterwards to the 'right' settings
does that mean the injector table will be leaner across the board?
BHDave - can you please check if that 0.2ms is correct? Because i'm running the nismo 740's on my
sr and the settings were already wrong.... but using the calculations shouldn't the lag time be 0.08?
50% - 0.08ms (0.66-0.58).
thanks for the replies guys.
Does this mean my lag time of 0.40ms is shithouse, and should be 0.13ms (0.71- 0.58)?
Yeah, I'm not sure it would run properly with that much...
Put your lag time to +0.12 dude.
As for the trim % on each injector I wouldnt touch those unless you are absolutely sure he didnt apply the trim straight to the INJ correction map [ which is very easy to do in datalogit ].
I'll try and remember to check tonight.
If the lag times that you have listed are corrent then you will be right. I just seem to remember .02 for some reason. Either way if you have a higher number and the car has been tuned with those setting s in already then there shouldn't be a problem.
ok thanks BHDave..
I did some searching...and found these
nismo injectors
555cc lag time - 0.71ms
740cc lag time - 0.66ms
from pfc manual
ecr33 rb25det
370cc lag time - 0.528ms
sr20det
370cc lag time - 0.58ms
for example if the figures were wrong, say proper was 50% - 0.08ms and 50% - 0.20ms was put in,
will that make the idle or the rest of the map extra rich?
I checked my apex chart and it shows the nissan 370's as .64, the 550's at about .67 and the 740's at .66
So thats where my .02 came from.
Either way, if it's tuned right then a slight difference in lag time will make little difference as lag is added to the open time to get a certain amount of fuel.
From my basic understanding of the whole thing (and i could be wrong here)
Say for example that the engine needs a certain amount of fuel to acheive correct a/f ratios, then the ecu triggers the injector for a set time (lag time) plus the user (or tuner) entered value of say 3.00ms for an example.
With stock injectors it will provide power to the injector (according to my info anyway) for 3.64ms.
chuck in a set of 740's (double the size, makes it easy) the injector needs to be powered up for .64ms (stock lag) plus difference in lag (.02) plus 1.5ms (due to the injector being double the size not considering all the fluid dynamics and stuff involved) so total powered time will be 2.16ms.
If you have a different lag time (say .12) with the same 740cc injectors, to get the same amount of fuel in you will have .64 + .12 + 1.4ms (user/tuner entered) for a total powered time of 2.16ms if you get my drift.
The only thing that i'm missing is the point in time when the injector gets powered up as i think that will make a difference, particularly when you are talking about such small open times, what i'm getting at is if you input a really big lag time will the injector be powered up earlier than with a small lag time or is the opening time fixed and the closing time altered? If it opens too early is the fuel hitting the back of the valve rather than getting pulled/puhed into the cylinder?
Edited by BHDave
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
