Batmbl Gb: Catco 3" High Flow Bolt-on Cats
Driftn 180
 Share
Hi guys
It has been asked many times for a group buy to be organised for the CATCO 3" high flow cats, so finally, here it is!
The 3 types of 3" cats available as bolt on for the R32 GTST/GTR, R33 GTST/GTR & R34 GTT Skylines are as follows (These same cats are also available bolt on for the S14 and S15 200SX) :
3" small body BOLT ON Catco cat (ceramic inside)
3" large body BOLT ON Catco cat (ceramic inside)
3" metal Catco cat BOLT ON (5" round body, 200csi metal inside - 706.2 CFM!)
Competitor cats either have a 200csi substrate with 4" body (Metal Cat) or 300csi substrate with 4" body (Magic Cat), making them inferior in flow to the CATCO metal cat.
ALL 3 of these CATCO CATS comply with EPA and CARB requirements and are made in the USA. There has been 100's sold through the SAU forums and not one problem has occured, EVER! so you know you are buying quality!
Take advantage of these rare GB prices! A min of 10 people is needed and it can be any one of the cats above. Note the metal CATCO cat is $90 cheaper and the price includes delivery!
Please list your interest in the thread below by stating which cat you are after and which car its for. All payments must be in by the GB close date of 9/06/06. BATMBL will provide bank account details through PM, so please also send your address details this way to him.
Edited by Driftn 180
  • Replies 67
Christian,
It is unlikely that your GTR has 2 cats, as they all come with one as standard, so it would be pointless for someone to spend extra money to put another in. Also, they normally do the dual exhaust after the cat, but to be 100% sure, just check it on your car anyways.
cheers mate
(B1) MR_fanny,
since the CATs are at GB prices, yes it will be cheaper to get the cat through the GB and the pipe seperately. at the moment the stainless split pipes are $430, so i recommend you get one of these instead. i can take off another $20 from the order if you pickup both parts, i.e $760 all up for pickup. thats the best absolute best i can do, a huge saving from before.
darrinspencer,
You wont notice any exhaust noise/note change between the 2 cats or from your previous cat to one of these, mainly because cats arent made to quiten down your exhaust like middle mufflers or resonators. the flow is much better obvisouly but it doesnt impact on the noise at all. regarding my recommendation, if you want the most you can get out of your exhaust, id go with the metal catco cat, especially at that power level, you just want to get the best flow and highest power figures.
yogi000,
updated the list, thanks
Xizor,
The Metal Cat is a great cat, it uses the same 200csi cell the catco uses, but i havent seen it in a 5" body, only a 4" body, so the cell is only 4" round not 5" like the catco.
The problem with these cats is that they are too short from one end to the other to make them bolt on for skylines or any other import for that matter (probably many other cars too). This basically means that exhaust shops would have to custom weld them straight to custom exhausts, which is fine if you dont care about your cat-back not being able to bolt on if you bought it from Japan or you want to sell it later on to someone else for a bolt on fit.
With the 'Metal Cat', you have to weld extra 3" piping to it and then the flanges can be welded on to make it bolt on. The Catco metal cats are long enough so they are actually cut to size and the flanges just welded on directly. Not enough research on Metal Cat's part i think, especially if they are trying to appeal to the turbo market with bolt on parts.
If there is a 5" body Metal cat, the structure would be practically the same as the Catco i would gather, as the metal substrate it uses would be the same as the Catco (200csi). Whether these 5" body Metal Cats are long enough to make bolt on though i wouldnt know as i havent heard of them before. Their main 4" body cat flows at 629CFM (second highest flow rate in the market, but still not near the Catco) on the same bench when tested with the Catco at 706CFM, so if they did make a 5" body cat, it might get similar flow results as the Catco, but saying that its better, i doubt that anyone could come up with a conclusion like that unless it has been bench flowed on the same equipment..especially when the construction would be the same and the inside would be the same. I still prefer the Catco over metal cat, as the Metal Cats seem to be 'following' the market and not leading it in the metal substrate cats like Catco.
cheers
The term 'honeycomb' reffers to a 'ceramic inside' cat because it looks like a honeycomb. its the same colour (yellowish) and has a similar pattern to a honeycomb. the proper term would be ceramic substrate. btw, almost all cats are stainless steel, just different grades. the catco metal cat is the 304 grade steel, and its polished, thus the shiny appearance.
the cats with metal inside are just refered to as metal substrate. if they are trying to sell you a ceramic inside cat, and saying it will flow more than a metal substrate cat with a 200csi cell then id run away quick.
ceramic inside cats wont flow as high as the metal inside cats due to the holes being smaller in the ceramic substrates (all are 400csi). of course the flow would definately increase over the stock cat/compliance cat, but if you are comparing the two 3" cats together, then the metal is higher flowing hands down.
cheers
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
