OK,
After having my 9th knee surgery I figure I gotta look after my legs a bit better, being 6ft8 and driving a Stagea is quite cramped for leg room, comfort etc.
I need the drivers seat rails extended in length so that I can drive it with the seat extended right back to the rear seats, and my wife can drive it with the seat at the closet position to the controls. I also figure it should have an engineers certificate in case of a accident & insurance claim.
Wouldnt mind a nice comfy Recaro but I can add that later. Where should I be going to have this done? Im thinking Willshere Motor Trimmers but does anyone have any suggestions?
Brendan
https://www.sau.com.au/forums/topic/120103-seat-rails-extended/
Alternatively, what are the dangers of taking out my seat rail, and redrilling holes further backwards, and bolting the seat back into these new holes, so it sits further back?
Is that legal?
Again, where can I get this done? I cant kneel anymore so therefore I cant do it myself.
Edited by Tangles
your best bet is to ring around some places. whillshere are the most $$ place in adelaide.... got to them and expect to pay at least 500$ per seat.... . most car seats usually have a rail that attaches to the floor and a second rail that slides in this and is attached to the seat... what you may be able to do is mount the rail attached to the seat further forward - which will ofset the seat further backwards in relation to its original position... however this will mean that you will lose x cm from the closest point you can now put your seat to the steering wheel. mounting seats is a right pain in the arse... i didi it in my alfa with some recaro style ones and eneded out getting a friend to help me do it (he has a whole heap of metal working equip) the thing is to keep it legal allways try and use the factory mounts and brackets - just modify them and make sure you use material that is stronger than the factory metal... perhaps if you remove thepassenger seat, take the rails of and have a think about it you might find a reasonable and easy solution... if you take the passenger one out post some pics and i might be able to suggest something.good luck
Brendan as for the legality of doin it............ahhhhh i wouldn't worry about it, because of some other stuff on your car. Even if you were to get defected for other things than that and had to go to regency you would put the rails back in! And besides don't think a cop would realise unless you were sitting in the back seat(and in your case you prob could)
Cheers for the advice. Thats a good idea about rebolting to the seat itself. Extra IQ points to you MrAnderson! If not thru Willshere who else? ta for your thoughts.............
With legality, more worried about an accident where the seat 'possibly' goes thru the front window (lol). Questions would then be asked - how was the seat bolted in? Id reply (from my grave) "I used Mechano/lego nuts and bolts" :(
Yeah, more worried about insurance implications in case of an accident, couldnt care less about defect etc. I reckon itd almost be impossible to be defected for my seat if it was extended backwards as such.
well i wouldnt worry too much about the seat flying away :wave: the idea of using the orignial rial and floor mounting points is that they are how the car was designed from factory and thus the safest... if you look at most seat rails the steel used for them is quite thin - it gets its strength from being moulded into a C shape or similair. if your not keen on takling it yourself your best bet would be to ring around some race car prep and engineering places - as opposed to auto trimmers... some may do it but you will prob find more willingness to help and less $ from a genuine engineering or car prep place..
heres the details for a place i know of (they usually work on euro stuff but i understand they do everything)
Start (Sirius Track And Road Technology) LLoyd Clonan
Specialising in Race Car preparation and development and project completion
Address: U3/14 Barndioota Road, Salisbury Plain, South Australia
Fax: +618 (or 08) 8283 4502
Phone: +618 (or 08) 8283 1970
Email: [email protected]
give em a ring - perhaps they can help or point you in the right direction
Thanks Lucas, yeah sounds like thats probably the go. I guess I'll contact some engineering firms down south and see what can be done.
If I could kneel then Id take out the drivers seat and start measurements, etc, and go from there. As it is thats impossible for me, so I'll measure up my wifes seating position vs the very forward position, get the difference in length, and then go to an engineering firm and say "alter either the seat bolts or the seat rail by xcm"
Ta for your valuable input. Need some $$ now. LOL
Edited by Tangles
seeing 'Marvn' tomorrow :D so we'll see what we can work out.......
Fact is, I dont fit comfortably in the standard local fare (falcodores etc), so I need to safely modify one small section of the seat rail to suit me.
Id argue it in court if necessary (god forbid!) that whatever it is that I end up getting done to extend my drivers seat rail lenght is a completley safe modification, to suit me.
Edited by Tangles
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
