Hey all, just realised the car i'm about to purchase only has a standard clutch so I assume it isn't going to last for long. It's a manual R34 GTT. I'm looking at getting one of the 240rwkw organic clutches from the C & B groupbuy. Just wondering if I then buy an R34 lightened flywheel such as an ORC or NISMO, will it fit fine with the aftermarket clutch? (Organic Exedy) I assume that it will because the clutch would expect you to use your original flywheel right? and an aftermarket lightened flywheel should fit fine into a standard clutch... But I just want to make sure to be 100% safe.
Also does anyone know of an aftermarket clutch that's good to about 240rwkw that comes with a lightened flywheel? I'm looking at around $660 for the Exedy + $550ish for a lightened flywheel so if there's anything else around that has both for less than $1500 i'd be interested.
Thanks.
You shouldn't have any problems with upgrading your flywheel to a lighter type at the same time you change your clutch.
As Wogboy said above, try Extreme, it who I went through and I did similar to what you're doing here.
I got the C & B clutch kit (organic) and an Extreme 4.8kg flywheel for my R33 gts-t.
All up it ended up costing me $1,060 installed.
Thats: $320 for the clutch kit
$470 for the flywheel
And $270 for the install.
Here is the link to my post about it:
http://www.skylinesaustralia.com/forums/in...opic=102395&hl=
Another option you might want to look at seeing as you want to change your clutch and flywheel at the same time is a multi-plate type clutch as the flywheel is built into these units. They tend to be more progressive and have a larger clamping force (which can be distributed over two or three plates, rather than one) The only real downside is they tend to have a slight chatter in neutral. Remember don't be put off by the price of some of the kits, they include the flywheel! Don't forget that!
-Insu
So you're still happy with your decision to switch to a lightened flywheel? The C & B clutch is a bit more expensive for me because it's a pull type. The cheapest I could find at nengun and greenline that include a lightened flywheel is the Exedy Hyper multi plate (twin) for about $1800, so it looks like the C & B clutch and buying a flywheel is the way to go for me. Did you buy your Extreme 4.8kg flywheel from Adelaide Clutch Services?
Yeah I'm happy with getting my lightened flywheel from extreme. It works pretty well with the C&B clutch kit, and its perfect for me for the amount of power I have.
Basically the lightened flywheel just makes the car so much easier to drive and more rev happy. It also seems to come on to boost a little faster, I guess this is because the car goes through the rev range quicker.
Oh and don't worry about whether or not the combo is streetable or not, I had all sorts of people telling me it was going to be a pig to drive, but in actual fact its a dream.
You wouldn't know it had a lightened flywheel after a week of driving and you're used to it.
Check out the post I made to the link I made about my experiences with the clutch dude, its all in there.
I think I got a pretty good deal for a heavy duty clutch kit+lightened flywheel+install for just over $1k.
Thanks mate, definitely gonna go for the lightened flywheel option then.
Just to let other R34GTT owners know, the cheapest deal I could find was the C & B organic clutch (240rwkw) $660 and a 5.5kg chrome moly flywheel from Adelaide Clutch Service for $420. So that's $1080 + installation.
  • 1 month later...
Im going for C&B, R34 HD organic kit for $650, Marz refered me to someone selling a lightened flywheel 5.5kg Chromemoly Xtreme for $480 delivered. Now is a matter of finding a good place to install.
So you stuck with the stock flywheel and just got it lightened...?
Sorry mate wrong info.., I got a new light flywheel, but i asked to get it machined, but u dont need to machine a new one, so basically its $300
Funny tho, Sum People say they find it different to drive with a new lighter flywheel, I found it the same as my stock one for some reason, tho better performance.
Ah okay yeah that makes sense, I was wondering why you would have to get a new flywheel machined heh. Just need to save up my pennies and i'll be going the same route. Does the clutch feel much different than the stock? I'm thinking of going for the next one up (5 puk 300rwkw) because I eventually want to upgrade to a GCG hi-flow.
Yep the clutch feels better imo, probably because the old one was worn out, but with the organic its much lighter than the standard clutch, also the point of where it bites is much more further up so it gives u a bit of exercise to push the clutch all the way in instead of going halfway to change gears originally, but then again its lighter so it kinda balances good and bad out.
Im guessing with your way its gonna be heavier push as your aiming for a more beefier clutch.
  • 3 weeks later...
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
