GDay,
I need to sell the following items:
1 x R33 GTR oil pump. Used for about 5000kms. Replaced due to upgrade. No damage. $100
1 x Hybrid Bar and Plate intercooler. 600 x 300 x 76mm. Excellent condition. $100. (Intercooler now sold)
Postage extra.
Ive also got an air conditioning compressor off an R32 gtst. $100.
1 x Alternator (R32 gtst) $100
1 x R32 gtst HICAS power steering pump. $100
All the standard air conditioning equipment off an R32 gtst. Condenser, thermo, all lines intact. $100 the lot.
Standard R32gtst air box. $50
Standard R33 GTR exhaust manifolds $70 neg??
1 x rooted R33 GTR turbo $50 neg
1 x R33 gtr starter motor, excellent condition. $150 neg
Shaun
0414972596
Edited by Shaun
Yes im sure it will. Im not sure if you need a crank collar to prevent premature failure of the oil pump drive gear that is common in R32 gtrs though.
Id ask someone in the know before purchasing though. The pump has seen very little use.
Shaun.
Ill have to do it in a few days time, as im working til tuesday and the cooler is at my parents place. It has three anchor points (one middle top, and two at the bottom) which take 8mm bolts, Its a standard gtr size, bar and plate construction, ive polished it on an 8inch bench polisher, no damage. In the photo, it looks like there are heaps of bent fins for some reason, however this is not the case. It performs really well, as i had inlet and outlet temp sensors on my IC piping. The inlet temps were never much above ambient with a GT30 at 19psi.
Shaun
0414972596
  • 3 weeks later...
