Hi Guys and Girls
Just an update on the progression of our dyno we are happy to anounce that our dynapack dyno will be arriving in early june and that the room(see pics) is in place ready for the arrival of the Dyno. This will be the first 4WD Dynapack dyno in Queensland for those who are interested in more details check out www.dynapack.com. The model we are getting is the 4WD 5032 model. Once the dyno is up and running we will be having a dyno day to show it action.....
Cheers Dave
Edited by GTAUTO
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/
bit of a silly question.. but can u still tune/ dyno a RWD on the 4WD dyno's? you guys are pretty close to me.. and i'd be keen for a tune up.. dont know who to choose to do some mods/tuning to my car yet.. i guess i gotta find someone who is trustworthy.
keep us updated
Cheers
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2242808
mods = dan (3lit3 32)
tune = Matt Spry (pits down the gold coast).
everyone here recommends them and from experience, so do i!
While I agree that Dan and Matt are great, a PM would have been a more appropriate way to express that.
I met Alex this morning (bought my wheels off me). He is good to deal with. Can't wait to check out the dyno.
Damien
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2244567
Hey guys the dyno has finally arrived just thought i would post up some pics so that you can see the dyno and the room together!! the final ventilation for the room is getting done this week and then we will be all go!! As you can see it is a bit different to your average dyno, hubs get bolted directly to the car thus it eliminates tire slip and makes for very accurate readings and tuning.
cheers dave
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2267715
Col- it takes about 20mins to have the car set up for a run slightly longer for 4wd drives, the car hardly moves on the dyno one of the reason we bought it was the saftey factor.
We will post up some prices tomorrow for the dyno. we will be having a special for the first month so stay tuned.
But this will only happen once the ventilation is done.
cheers
Edited by GTAUTO
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2269017
we have no probs with my gtr on dyno dynamics....920hp at all 4 wheels yesterday.....
dyna packs are no good for dyno days or power runs.. takes too long...set up..
Its good to see a dynapack dyno around i know a few people with wheel spin problems on dynos that will be interested
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2277832
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
    • Thanks for the details mate , for me I think being a daily driven and happy with a basic tune (630Nm and 310kw) . Seems to be working well I just put on a set of Michelin Pilot Sport 4 should help put the power down. I'm going to start looking a brakes and LSD in the future so I might reach out to you on options to upgrade the brakes. Cheers - Dee
    • I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last.  Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working?   Any insight is appreciated. This is a rather new to me car. Lol
