Hi Guys and Girls
Just an update on the progression of our dyno we are happy to anounce that our dynapack dyno will be arriving in early june and that the room(see pics) is in place ready for the arrival of the Dyno. This will be the first 4WD Dynapack dyno in Queensland for those who are interested in more details check out www.dynapack.com. The model we are getting is the 4WD 5032 model. Once the dyno is up and running we will be having a dyno day to show it action.....
Cheers Dave
Edited by GTAUTO
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/
bit of a silly question.. but can u still tune/ dyno a RWD on the 4WD dyno's? you guys are pretty close to me.. and i'd be keen for a tune up.. dont know who to choose to do some mods/tuning to my car yet.. i guess i gotta find someone who is trustworthy.
keep us updated
Cheers
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2242808
mods = dan (3lit3 32)
tune = Matt Spry (pits down the gold coast).
everyone here recommends them and from experience, so do i!
While I agree that Dan and Matt are great, a PM would have been a more appropriate way to express that.
I met Alex this morning (bought my wheels off me). He is good to deal with. Can't wait to check out the dyno.
Damien
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2244567
Hey guys the dyno has finally arrived just thought i would post up some pics so that you can see the dyno and the room together!! the final ventilation for the room is getting done this week and then we will be all go!! As you can see it is a bit different to your average dyno, hubs get bolted directly to the car thus it eliminates tire slip and makes for very accurate readings and tuning.
cheers dave
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2267715
Col- it takes about 20mins to have the car set up for a run slightly longer for 4wd drives, the car hardly moves on the dyno one of the reason we bought it was the saftey factor.
We will post up some prices tomorrow for the dyno. we will be having a special for the first month so stay tuned.
But this will only happen once the ventilation is done.
cheers
Edited by GTAUTO
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2269017
we have no probs with my gtr on dyno dynamics....920hp at all 4 wheels yesterday.....
dyna packs are no good for dyno days or power runs.. takes too long...set up..
Its good to see a dynapack dyno around i know a few people with wheel spin problems on dynos that will be interested
https://www.sau.com.au/forums/topic/120140-gt-auto-dyno/#findComment-2277832
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
