Ok guys i'm organising a group buy for the GKTech front mount kits.
Starting 30/5 and ending in 2 weeks on the 13th/5 (or when we have 10 buyers, another GB will be started if this 1 fills)
Kits available to suit
S13/S14/S15
R32/R33/R34
A31
RNN14 GTi-R AND GC8 WRX!!
Details on the kits :
The front mount bar and plate intercooler kits are constructed entirely of high quality 6061 aluminum and the intercooler core is 100% vacuum brazed. The polished aluminum end tanks are hand TIG welded for a perfect fit. The ambient fin pitch has been adjusted to provide an optimal fin density of 15 fins/inch. This gives the intercooler excellent flow properties as well as a large cooling surface area, and the efficient Bar & Plate core takes advantage of these properties. The piping is all mandrel bent and contains only 1 weld mark throughout the whole kit. The kit includes 1x 600x 300x 76mm intercooler, polished aluminimum piping, all brackets, nuts, bolts, tripple layer silicon hoses, clamps etc.
The kits are designed to be installed DIY and are very easy to install.
Features & Specs:
-All TIG Welded 6061 Aluminum, polished end tanks
-100% Vacuum Brazed Core
-High Efficiency Bar & Plate Construction
-3 popular Sizes available
-Inlet/Outlet: 3inch
-Low pressure drop w/ only 0.2psi at 15psi of boost
-Tested CFM: 1020 CFM
-Fin Pitch: 15 Fins/Inch
-Four Threaded Universal Mounting Points
We need 10 buyers for the GB to go ahead, so post in here if you're in. Kits will be purchased once we have 10 buyers, and sent out soon after purchase.
Price for each kit is $400 + postage (see below for postage cost) and pickup will be available from me in Melb. (Western suburbs)
Thats a saving of $50 on the normal price of these great quality kits :D
FREIGHT: (all items are sent out by registered post with full insurance)
VIC: $30
SA/NSW: $45
QLD: $50
WA/NT: $70
1. broadz - WRX
2. KillaFlop - WRX
3. QRI05E - R33 GTS-T
4. bilbo117 - R33 GTS-T
5.
6.
7.
8.
9.
10.
Interested
rice_me_Up
https://www.sau.com.au/forums/topic/120149-gb-2-gktech-front-mount-kits-400/
Which pic(s) actually relate to R33 S2 kit?
Can we get some pics of the unit installed and comments from people of the last group buy/who have it installed?
When they get their kits and get them fitted im sure someone can post pics..
The pics in the post are the GTS-T kits :D
Hello I would like to know the size of the piping on the r33 kit thanks
2.5" mandrel bent polished aluminium
I look forward to hearing if they will fit a Foz!
Will let you know asap
We can't guarantee the fitment on a forester. These kits are
IDENTICAL to the Hybrid GC8 kits so if they fit, then so will ours.
Also guys, the hose clamps supplied in the kit are stainless steel, and great quality :D
The kits actually left the post office this morning and not yesterday afternoon. They were dropped off yesterday afternoon but unfortunately due to the 34 boxes that I needed to send out at the same time they couldn't have them all ready before the close of trade :)
Please post up when your kit arrives (should take anywhere from 1-5 working days depending on you location within Australia).
cheers,
Greg
I am pretty sure the Hybrid kits won't fit an SF5 Forester. Oh well :dry:
It really depends on how far the kits off from fitting on your car. If it is only a little bit of mucking around to fit on a different car than intended then it will still be a very cheap option over custom. If it's nothing like the WRX kit then it's best to go custom.
Only you can decide if it's worth it or not.
Greg
Problem is I am not 100% sure why it doesn't fit just know it doesn't. If I was in Melbourne I would just pop in for you guys to have a look but being based in Adelaide makes it a bit more difficult for me to do that. If I could russle up someone in Melbourne do you think you could take a look and let me know?
Michael
Michael
Hi Micheal, unfortunately it makes it very hard as the kit is designed specifically for the GC8 WRX.
As far as modifying it we don't know and wouldn't know until it is fitted to a car which would take a fwe hours to even determine.
If you're in a Subaru club or something like that, possibly someone on there can help? Maybe someone on there has attempted to fit a WRX kit to a Forester, as we just really don't know if it will fit, and can't guarantee if it will fit to a car other than specified.
Sorry for not being able to help you too much :(
Greg
OK apparently the kit will fit an SF5 Forester with slight mods, but it maystick out the bottom of the bumper, ideally for a Forester the core needs to be 600x260x76. I have posted a link to this thread on the gtrydaz forum as well now.
Michael
Michael
ok, so would you like a kit or?
That bit I haven't worked out yet $$$ are a bit tight at the moment, this is almost too good to pass up though, I might have a chat to my tuner about it and see what he says.
Michael
Common guys, this is a once in a life time opportunity! When are you ever going to find an excellent quality FMIC kit with EVERYTHING needed to install for $400?? Even if after 12 months it stuffs up just replace the core for a name brand and use the same piping!!! you will save $$$ either way...
Regards,
Sarkis
Edited by QRI05E
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
