Hope I'm in the right thread and if not, sorry mods!
Hey guyz,
Just wondering if any of you guys know a business that paints rims around the Western Suburbs, Victoria? It can either be powder coating or spray painting, as long as it's a good job and cheap. Would prefer people that's done business with them so I can get some feedbacks.
Thanks!
John.
My rims were powder-coated in Airport West, for about $120 for all 4, but i knew the guy through my mechanic. Either way, the painter has left the business and the business has moved to another shop somewhere near by, but am yet to find where. Apart from a good clean and a light sand, no prep work was required for my rims.
$220 is a great price.
I sprayed my wheels with a can from autobarn. Simply becuase they are 200 dollar wheels and i thought powerder caoting would cost be about 300 and i wasnt willing to spend that.
The finish came up better than expected (didnt really know what to expect) and the durability has surprised me a little. with no scratches or anything yet (have been spray for about 2 months.
If i was to do it again the only thing i would do differently is spray with some sort of clear coat laca or something. something with a bit of toughness and a little more smooth, as the paint texture seems to hold dirt/dust pretty well.
I give them a light polish evrey 4 or 5 car washes and that makes the brake dust come off with ease :D
here is a pic about 3 weeks after spraying.
Cheers
umm..
they were around 14 bucks each. and all 4 wheels took about a can and a half.. did a really light coat on each wheel, then a much heavier 2nd coat.
In my opinion. I am very hapy with them, considering it cost me under 30 bucks, and they look like brand new wheels :)
spray can for the win! :D
Cheers
Steve
Just found the details, ask for Tim do the powder coating.
T&C Powder Coating
Contact: Tim (owner)
Tel: 9338 6631
Add: 12 Marshall Rd, Airport West.
Just got a quote to powder coat a new set of 18" rims (no prep work required), using gloss black, $120 for all four rims :).
If the rims need to be sand-blasted, etc, it will obviously cost more.
T&C Powder Coating
Tel: 9338 6631
Mine are going into Tim tomorrow. I'll let you know how they go.
PM Age, he's sprayed several sets of wheels.
The WRX club has had rim painting days where several people got together and did a load at once.
They had the wheels off the car, masked the tyresoff with tape and newspaper. I believe they gave them a light sand (something like 1200 grit), then under coated, then sprayed, then clear lacquer, couple of coats of each I seem to remember.
They came up great and last well, I reckon stones are gonna chip no matter who paints them.
There is a DIY on the Rex club site, but its in the members only section.
The wheels went from this
To this
Using these
Black, charcoal, gunmetal and white have all been popular
Edited by wokka wokka
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
