Hay guys im just wondering if any of you know what the initili data does on the power fc as i have gorn in to that setting it gives you a option yes/no and for some reason i selected yes before this the car was running fine but all above that is in japanese.any help would be appreshated as the car at the moment if coughing and spluttering and bearly starting cheers
https://www.sau.com.au/forums/topic/120251-powerfc-problem/
if you've selected YES to DATA INIT then its back to factory defaults.
The car is now ready for the self idle learn procedure. You simply need to do this. If the idle is jerky and unstable. Turn car to ACC, do DATA INIT again. Turn car off. Turn car on and follow idle self learn procedure, its in the FAQ in my signature
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2214968
Cheers guys but at the moment the car wont even start, it trys to but just wont turn over is this normal? also i didnt do the self learn procedure when i first pluged it in and it was fine every was fine till it hit that button inital data.
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2215690
if you dont perform the self idle learn procedure the car will crank, start and stall almost immediately. if you have this, turn to ACC (dont start), choose DATA INIT, YES, turn car off and then perform self learn idle procedure
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2215932
His car is not starting so he cannot do the self learning idle procedure.
joc - basically what you have done is resetted the power fc, if it has been tuned before which
sounds like it has then all the settings are gone if you havn't written them down.
Have you changed injectors or air flow meter?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2216727
joc,
Tell us... Have you had the car tuned or did the car come with the pfc?
I bought the power fc last week put it in on monday,was fidlling around with it(not noing what i was doing)there is no tune on it unless thay have one when u get the unit.any way got car running last nite did learn procedure worked fine last nite started car this morning and she was spluttering and going on baically the car sounded like a wrx with little to no power what do u guys think.
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2218833
thanks bhdave i thought somthing might be a miss but turn off boost controll kit and light went away,guys the car seems to be running alright now the test will be when i go and start it tommorow morning,like it did this morning spluttering and going on.Just one more question does the power fc have to get used to cold starts?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2219998
Hay THE MAFIA how do i read the manual if its in japanese.Hay guys is there any reasond why i have problems with the pfc in the morning on cold starts cause on the way home from work in the arvo the car runs fine.Does the pfc have to learn cold starts?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2221731
before you start the car, under monitor check out water temp
then jump to the corresponding water temp correctio braket and try increasing the MS value for it. make sure you note down the numbers before fiddling. it may help it crank over a bit better when cold. cubes has done this and it sorted out his cold start problems for water temp at 10deg
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2222128
Yeah im going to tune it but am waiting to get cam gears and replace timing belt as it due to be replaced also i want to boost it so i dont want to tune it till then.but i thought with the power fc you could just plug and play,just as long as you dont go flooring it every where,anyway so you think its the water temp,maybe i should do the learn procedure in the morning when its cold what do u think?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2222523
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
