Hay guys im just wondering if any of you know what the initili data does on the power fc as i have gorn in to that setting it gives you a option yes/no and for some reason i selected yes before this the car was running fine but all above that is in japanese.any help would be appreshated as the car at the moment if coughing and spluttering and bearly starting cheers
https://www.sau.com.au/forums/topic/120251-powerfc-problem/
if you've selected YES to DATA INIT then its back to factory defaults.
The car is now ready for the self idle learn procedure. You simply need to do this. If the idle is jerky and unstable. Turn car to ACC, do DATA INIT again. Turn car off. Turn car on and follow idle self learn procedure, its in the FAQ in my signature
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2214968
Cheers guys but at the moment the car wont even start, it trys to but just wont turn over is this normal? also i didnt do the self learn procedure when i first pluged it in and it was fine every was fine till it hit that button inital data.
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2215690
if you dont perform the self idle learn procedure the car will crank, start and stall almost immediately. if you have this, turn to ACC (dont start), choose DATA INIT, YES, turn car off and then perform self learn idle procedure
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2215932
His car is not starting so he cannot do the self learning idle procedure.
joc - basically what you have done is resetted the power fc, if it has been tuned before which
sounds like it has then all the settings are gone if you havn't written them down.
Have you changed injectors or air flow meter?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2216727
joc,
Tell us... Have you had the car tuned or did the car come with the pfc?
I bought the power fc last week put it in on monday,was fidlling around with it(not noing what i was doing)there is no tune on it unless thay have one when u get the unit.any way got car running last nite did learn procedure worked fine last nite started car this morning and she was spluttering and going on baically the car sounded like a wrx with little to no power what do u guys think.
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2218833
thanks bhdave i thought somthing might be a miss but turn off boost controll kit and light went away,guys the car seems to be running alright now the test will be when i go and start it tommorow morning,like it did this morning spluttering and going on.Just one more question does the power fc have to get used to cold starts?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2219998
Hay THE MAFIA how do i read the manual if its in japanese.Hay guys is there any reasond why i have problems with the pfc in the morning on cold starts cause on the way home from work in the arvo the car runs fine.Does the pfc have to learn cold starts?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2221731
before you start the car, under monitor check out water temp
then jump to the corresponding water temp correctio braket and try increasing the MS value for it. make sure you note down the numbers before fiddling. it may help it crank over a bit better when cold. cubes has done this and it sorted out his cold start problems for water temp at 10deg
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2222128
Yeah im going to tune it but am waiting to get cam gears and replace timing belt as it due to be replaced also i want to boost it so i dont want to tune it till then.but i thought with the power fc you could just plug and play,just as long as you dont go flooring it every where,anyway so you think its the water temp,maybe i should do the learn procedure in the morning when its cold what do u think?
https://www.sau.com.au/forums/topic/120251-powerfc-problem/#findComment-2222523
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
