Hey guys,
I would like to put in new bulbs for the dash. And also would like to add in a dash light dimmer. So that I can adjust the brightness of the light. Just want to know what wires I need to attach a potenmeter (sp?) to?
Or let me know what switch/module I can make/solder etc.. to make one.
Thanks
https://www.sau.com.au/forums/topic/120299-dash-light-dimmer/
go to dick smith or somewhere like that to get a dimmer. it is the same thing that you would use for a front/rear speaker fader. generally they have 4 (2 in, 2 out) wires on them. you will only need to use 2 (1 in, 1 out) of them. also you will need to find out which wire is the light wire on the back of the dash.
easiest way is with a test light or multimeter. LED test light recommended over bulb test light, but multimeter is best. to find out take the dash out, but leave it plugged in. the switch on the lights and remove 1 plug at a time to narrow down which plug contains the wire. even after you find it check all the others to make sure it isn't multi feed. then it is time to find the wire in the plug. then once you have the wire then add in the dimmer switch. you will probably need to add some wire so that you can positition the switch where you want.
Its called a potensiometer (or pot... dse guys will know what you mean). You'd need a fairly beefy one, 2 watts atleast I'd say and about 500 ohms.
They only have 3 terminals. Its basically two variable resistors, where the middle pin in the common between them and the two outer pins are there inputs. As you turn the knob one resistor will increase resistance and the other will decrease.
You only need to use one of them so the wires need to go between the middle pin and one of the outside pins. Snips either the lights 12v or ground wire and connect them to the pot and that should be it.
  • 8 months later...
hmm reading this has got us pondering, we are replacing the damaged wiring from the car-steal shit
at the moment the clock and the dash doesn't work for lights, are these linked for the dimmer reasons? where can i find a feed to the instrument cluster so i can feed off the park lights at least, the c**ts made a real mess of the loom and im not sure i can find where they were connected originally
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
