  • Replies 242
I get usually anywhere from 380-420k's to a tank, fill up around 3 times a fortnight, mostly freeway driving, but still quite good regardless for a 350rwhp car. 320ks has been my lowest ever tank because it involved 2 cruises & 3 days. :)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2217977
The GTR tank is spose to be about 72L, but when I fill up I put $70 in which fills it up quite full. $70 = 46.6L, is my tank smaller or something???
I usually manage about 380k's, 90% of that is peak hour traffic. I got 430k's a few weeks ago, I was quite proud :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218512
Damn $70... I only spend on average $55 a week
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218629
Oh how the hell do you guys manage so many km's out of a tank? I get about 250km out of a tank of BP 98 and I have to fill up twice a week. 50% of driving time is open road and the other half is in the city.... :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218697
i get around 450 a tank in my gtr ..
Tom yes a gtr tank is 72 litres but there is asort of air pocket in them the most u would ever be able to put in them is about 65 litres
i can only fit 63 litres in mine if the low fuel light is on
most weeks i use around 80 bux for fuel (over 10000 k's since i gotthe car in January)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218875
Hey Nastazia...is the tank empty though...ie when you fill up how many litres can you squeeze in? Reason I say that is the fuel senders in the 33 can be a bit dodgy sometimes and give a false reading. Should definitely be getting more than 250km in a fairly stock skyline.
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2219435
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
