  • Replies 242
I've got an auto as well and manage to get 400km on a tank before I cave in and get some fuel, at this stage it's been sitting just above the 'E' for a while now. This is done on 'grandpa' city driving with full exhaust, FMIC, EBC, pod and piggy back ECU.
I used to only get 250km's from absolutely-full-tank to just above the 'E' mark. I just changed my O2 sensor and then I could reach the magic 400+ mark, then I got my ECU tuned and things seem to have improved a little more still.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2474655
cool thanks :P yea had my oxy sensor done 5 000km ago too
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2474989
hay guys, i replaced my 02 sensor today with an NGK item, and i had a long discussion with the bosch guys down here in tas. THE EL FALCON O2 is not anywhere the same, but somehow it manages to work, the heating element is different, and the output thershold is different.
I have noticed a BIG difference in the NGK item, the sensor is simmilar to stock but has different inside parts. I also replaced the ECu temperature sensor, the car is sooo much better now, going to see how it goes with the fuel economy.
I also replaced the plugs gapped to 1.1mm and i have to change them back to .8. It deffinatly pulles better with .8's
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2475702
I put in $50 or 34L on Wed and got 250kms out of it - (run down to red light). I have an auto fairly stock 33 running 190HP on stock boost... Is anyone else in an auto getting the same?
Gees! you must thrash it round! ;) I always get over 400kms, today I got 430 odd! (auto)
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476026
' date='8 Sep 2006, 09:28 PM' post='2475808']
how big is an r33 gtst tank?
i fill up around 270-300km and i get around 40L in
thou im running over 300hp with 11:1 afr, and hit the limiter constantly on most days hahha
Should be about 65L tank, and you should stop puttin that foot down so much man ;) I got 58L in mine today, I did run it down bit more than usual.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476027
Should be about 65L tank, and you should stop puttin that foot down so much man :) I got 58L in mine today, I did run it down bit more than usual.
ohh thanks for that pulp ;)
i think i can push it alittle bit more than to 350km... my fuel gauge doesnt work the best so i dont want to all the sudden run out of fuel ahaha :)
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2476037
I get around 450km out of 50L with my RB30E+T only mods are 3" catback and pod, I'm pretty happy with that, it's f**kall, if anything more than when it was NA
I Just filled up my car for the first time with the rb26 in and only got 235 kms out of the tank!!
i was shocked my fuel consumption halfed from the rb20. Im still running it in so i wasnt thrashing it. Im running a microtech ecu, is something wrong? do i need to retune or is this the reality of an rb26 running 310 rwhp ?
It's the Microtech, it doesn't have closed loop (unless new ones do?).
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2477374
closed loop? whats that?
Its the Lt 1200 model. running MAP
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2481342
The O2 sensor controls fuel mixtures when cruising, to give good fuel economy, The Microtech doesn't use this and is rich all the time, not just when when flogging it, not flogging it would still use less fuel but not as much less.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2486675
Arr ok. Interesting.. Wish i knew that before haha.
have spoken to someone else with a rb26 running microtch and they are getting mor like 300 km/tank heading back to rotomotion for a retune i think, unless anyone would recommend someone else who knows microtech well.
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2488059
play r 32, you should probably invest in a wideband sensor like this
Although you don't have closed loop, you should still be able to adjust your fuel maps so that when your cruising your sitting on an AFR of 15 or so to conserve fuel. Just get a mate with a laptop and go cruising :happy:
I'm guessing your tuner probably only did a WOT tune if your using that much fuel :laugh:
EDIT: Just forgot, my record so far is 8.9L/100km with a fair bit of nanna driving. I got 470km off 42 L... gotta love the RB20 :laugh:
https://www.sau.com.au/forums/topic/120328-fuel/page/7/#findComment-2539536
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
