Guys n Girls..
i'm looking to get an r33 either series 1 or 2 to buy in the next month or so... so id like to get an idea who has either of these models for sale in Melbourne currently.
my budget is between 18k - 27-28k obviously depending on series and mods that are on the car. I'm looking for an example with extremly good paint and reliable drivetrain with k's under 90k... mods dont mean that much to me as i'll prob chop n change whats on there already as every1's taste is different :D
Would appreciate pics and specs of any 33's for sale in melb to this thread.
Cheers
Mark S.
https://www.sau.com.au/forums/topic/12036-wtb-r33-skyilnes-in-melb/
dave,
is ure exhast turbo or catback? what size is it? if turbo back what kind of dump pipe do u have?
who remapped ure ECU and what did it modify from the stock computer.. n how much boost were u running to get 173kw at the wheels :P
cheers
mark
Originally posted by qikshift
dave,
who remapped ure ECU and what did it modify from the stock computer.. n how much boost were u running to get 173kw at the wheels :)
cheers
mark
exhaust is 3.5inch Tanabe LIMIT cat back. Currently no dump/front pipe but shopping for one (even tho im selling :P)
ECU was remapped by Selection tuning in Japan. It has a unique ID number so if you had the contacts, you could find out exactly what has been done. As far as I know it changes fueling, ignition etc.
Running 10pound for 173rwkw. Boost is 7pound from 3000-5000rpm and 10psi from 5000-7000rpm. I think this may be in the ECU too as there isnt any boost controllor elsewhere. I also change the oil, fuel filter, cleaned and gapped plugs last week, so hopefully it would squeeze out a few extra kw@the wheels now.
dave
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
