What once bought a smile to my face, has been replaced by more important things.
1995 BCNR33 GTR V-Spec
Midnight Purple
127,000km... mostly Adelaide to Mount Gambier open road
OS Giken Twin plate clutch
Custom Tuned OEM ECU - 250rwKw
HKS Cat Back
HKS Pods
Nismo damper adjustable only suspension
Pager Alarm System
Alpine MP3 Head unit, MB Quart Splits, Kenwood 3ways
Car Bra
12.5sec 1/4 mile at AIR in Oct 2004..... never run again since
Recent maintenance (last 6months)
- splitfire coils
- nangkang ultrasport 265/35's on Drift R 18"x9"
- redline shockproof gear oil
- replaced injectors
- new turbo, dump, and front pipe gaskets
- replaced aircon compressor
$30,000
TELL YOUR FRIENDS!
Edited by Pawley
  • Replies 53
Posted Images
  • 3 weeks later...
  • 3 weeks later...
