You have all been asked and many seem to still be ignoring the rules.
The next person that chats in this thread or disputes the price being asked will be issued with a warning
  • Replies 53
Posted Images
- new turbo, dump, and front pipe gaskets
$30,000
TELL YOUR FRIENDS!
Sorry if that was misleading, but it reads new gaskets for the turbos and ancillaries.
Whilst this was being performed however, the turbos were thoroughly inspected and deemed to be in exceptional health which was suprising for the km on the car. So either they have been replaced prior to my ownership, or I am backed up by my claims of an exceptionally well looked after car.
People will need to email/ PM if they want the oppurtunity to offer above what I am considering accepting. I am not prepared to advertise the price taken until the has sold.
serious offer received last night. STILL UNDER CONSIDERATION HOWEVER
car might go over the weekend.... worst part is that it will be for well under $30,000 :devil:
please let us know what it goes for!
i have a vx commodore s up for sale if your interested in a swap + cash?
http://www.skylinesaustralia.com/forums/in...howtopic=139588
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
