as you can see 300rwkw can be easily made on stock commondoor parts.
just need a good builder to check the basics and away you go, thats the point of the rb30det. drop in stock parts and rape it till it goes bang.
guys have used 200,000k bottom ends and have still been in near perfect condition
Then there's Bu5ters 8500rpm RB30DET monster. :)
3lit3_32,
You missed one VERY important part of a high rpm build. The oil pump drive crank collar.
The RB30 requires a fluid balancer (ati) for it to be reliable @ 7000-7500rpm+.
I was suprised how nice an RB30DET GT35R .82 was to drive. It made boost from as low as 2000rpm and hit hard around 3500rpm and this was on a fairly low comp rb30det as it was running stock rb30 n/a pistons and a 1.6mm head gasket. Off the top of my head a shade under 8:1.
A GT35R .82 on an RB25DET... I really wouldn't like to drive it lag isn't my thing.
For a daily driver, I wouldn't run larger than a gt3040 on the rb25. I tend to trust mr Nismoids spool/lag figures.. GT3040 .82 on rb25 I believe it got up and started to move at around 4000rpm.
Now drop the gt35r on the rb25 and your easily looking at another 500-600rpm.
Go 3ltr if you are hell bent on using a GT35 IMO.
700hp turbos are just not the RB25 cup of tea
calaisturbo.com
reults speak over there with the guys using GT35's on the 3ltrs with amazing response.
As for 450rwkw from a GT35... thats interesting. You'd be leaning on that ever so hard, and with race fuel to boot to make that sorta power
My Rb30DET has run 784rwp (without NOS) and a 9.3 sec quarter. Its rated to handle 1200+hp.
RB30 Bottom end
Cryoed crank
Arp rod bolts and head studs
Argo rods
Custom JE Pistons with with 22mm Gudgeon pins and lowered ring lands
3/4 grout filled block
copper head gasket
RB26 Head
Heavily ported by headsense
Heavy duty valve springs
HKS Cams
(i keep most of this info quiet)
Inlet plenum
105mm throttle body
Direct port NOS system (including soleniods and 10 pound bottle)
Rochester 1240cc injectors
Additional injector rail
Custom fuel rail
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
