Does anyone have photo's of where the castor adjustable bushes go?
or be able to describe to me in good enough detail which arm it is?
l know there is a thread with some photo's but l have looked for days and can not find it again. if someone could forward that, it would be greatly appreciated.
Cheers
PS. the forum search engine is pretty crappy :)
https://www.sau.com.au/forums/topic/120381-castor-bushes/
find the lower control arm, off that arm there is a bar/rod going forward held on to the arm with 2 bolts. That is the castor rod. the bushes go in the front of that. Big round ones. about 6" in diametre. Its basically the furtherest forward suspension bush on the car in the front.
Hope that helps.
https://www.sau.com.au/forums/topic/120381-castor-bushes/#findComment-2217712
how much would the rod have to bend for the castor to be a 0 degrees?
Impossible, the radius rod would have to be longer to get zero caster.
Hence straighter, therefore bent less, not more.
Usually less caster is caused by the front subframe (where the radius rod bolts to) being bent or displaced.
This happens when the wheel hits something rigid while the car is moving forwards (ie; straight ahead into a guttter will do it).
:mellow: cheers :mellow:
https://www.sau.com.au/forums/topic/120381-castor-bushes/#findComment-2218056
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
