Sorry, I should have been more specific. Was it in a car yard in Japan (that J-Spec contacted), or did J-Spec bid on it for you at auction in Japan?
Cheers :w00t:
It was with a dealer/caryard
A few days earlier I payed 390,000 FOB for a series 1 98 dayz model with 109k's from auction
  • Replies 44
wow thats incredible - less than 12.5k landed and complied... that devalues mine a lil bit then ey. Its done more than 3x the distance mine had, though, i guess.
Oh and it has the DAYZ kit... ive noticed that the grey ones are generally a lil bit cheaper, theres a lot more of them.
How would it go being complianced though, having had a manual conversion, big wheels, exhaust and suspension? what do you have to do with that?
most things have to be put back to standard....mine is just a dayz 97 model which had wheels and sports suspension and i had to get standard rims and i had to borrow stock suspension off another stagea driver to get it over compliance! (which is still going..2 and half weeks later) I think it also really depends on your compliance place, but majority of them return the car to 'stock' :P
Edited by Wildcat
So what they have to put an auto back into it????
hmm i dont see the point of buying a "race import only" stagea if that is the case. says 12,100 landed and complied... how accurate is that, then?
Sounds like buying a modified car can be more trouble than its worth, even one as cheap as this. May be that is why its cheap. hassle-tax.
i would have no idea about the manual..hopefully they would let that through :
as for the 12,100 landed and complied i dont think that would be too close to the mark...cause that is just standard compliance that doesnt take into account taking parts off getting standard parts fitting those and then putting the others back one...hopefully the compliance shop wouldnt take advantage and charge a fortune...
i tell you mine was 10600 landed and complied and i am going to hit about 13k so it was a little off the mark for mine too, but that is because of my extras that had to be taken off and put back on and find stock parts etc!
Wildcat
The shop doing my compliance has stock parts in the shop ie shocks, wheels, exhaust
Only charges $50/hr to remove and replace if needed, so maybe 2-4 hrs if needed
Also, what does the WA shop charge for compliance out of interest?
I was quoted $13,800 landed and complied
Will be $13,450 landed and complied
yeah darrin if i did go to brisbane i think i wouldnt have had much dramas as bretts (MrGTST) seemed to have no problems and was pretty much what we were told.
WA is more expensive than brissie...but with all of the extras they are charging i think i will be the 5k mark just to get the bloody thing complied! The only reason why it came to wa is because it was suppose to be here 3 weeks before bretts was....and brett got his yesterday :P I think mine will be able 13k on the road ready to go
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
