Sorry, I should have been more specific. Was it in a car yard in Japan (that J-Spec contacted), or did J-Spec bid on it for you at auction in Japan?
Cheers :w00t:
It was with a dealer/caryard
A few days earlier I payed 390,000 FOB for a series 1 98 dayz model with 109k's from auction
  • Replies 44
wow thats incredible - less than 12.5k landed and complied... that devalues mine a lil bit then ey. Its done more than 3x the distance mine had, though, i guess.
Oh and it has the DAYZ kit... ive noticed that the grey ones are generally a lil bit cheaper, theres a lot more of them.
How would it go being complianced though, having had a manual conversion, big wheels, exhaust and suspension? what do you have to do with that?
most things have to be put back to standard....mine is just a dayz 97 model which had wheels and sports suspension and i had to get standard rims and i had to borrow stock suspension off another stagea driver to get it over compliance! (which is still going..2 and half weeks later) I think it also really depends on your compliance place, but majority of them return the car to 'stock' :P
Edited by Wildcat
So what they have to put an auto back into it????
hmm i dont see the point of buying a "race import only" stagea if that is the case. says 12,100 landed and complied... how accurate is that, then?
Sounds like buying a modified car can be more trouble than its worth, even one as cheap as this. May be that is why its cheap. hassle-tax.
i would have no idea about the manual..hopefully they would let that through :
as for the 12,100 landed and complied i dont think that would be too close to the mark...cause that is just standard compliance that doesnt take into account taking parts off getting standard parts fitting those and then putting the others back one...hopefully the compliance shop wouldnt take advantage and charge a fortune...
i tell you mine was 10600 landed and complied and i am going to hit about 13k so it was a little off the mark for mine too, but that is because of my extras that had to be taken off and put back on and find stock parts etc!
Wildcat
The shop doing my compliance has stock parts in the shop ie shocks, wheels, exhaust
Only charges $50/hr to remove and replace if needed, so maybe 2-4 hrs if needed
Also, what does the WA shop charge for compliance out of interest?
I was quoted $13,800 landed and complied
Will be $13,450 landed and complied
yeah darrin if i did go to brisbane i think i wouldnt have had much dramas as bretts (MrGTST) seemed to have no problems and was pretty much what we were told.
WA is more expensive than brissie...but with all of the extras they are charging i think i will be the 5k mark just to get the bloody thing complied! The only reason why it came to wa is because it was suppose to be here 3 weeks before bretts was....and brett got his yesterday :P I think mine will be able 13k on the road ready to go
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
