Hey guys,
k over the last few months i have a worsening starting problem in the RB20DET. Battery is cranking it fine and starter too but it just doesnt want to turn it into an idle
Im also experiencing clutch in/braking stalls at lights which is particularly fun when it takes 10 cranks to get it going :D have to heel toe gas to keep alive mostly
cold start - about 1 in 3 cranks it will start
hot start - about 1 in 10 cranks to start the bugger, and both scenarios require throttle to gain a stable idle
I also had a miss a while back but replaced a faulty coil and renewed spark plugs and its now running very strongly and quite smooth.....when it finally gets going that is
other info:
battery new and charged
afm recently cleaned
aac valve cleaned
pretty sure no vaccum leaks
040 fuel pump earthed to chassis (not ecu) as per thread on here
Ive done a bit of research and from what i can gather possible causes of this could be:
leaking injector/s or fuel pressure reg??
faulty coolant temp sensor
ignitor faulty/ overheating
coils again, but there is no miss really and power is good??
Thx for reading would really apprec some input/help/ideas as to why it doesnt want to start properly and stalls now and again!!!!
car has:
rb25 turbo, fmic, pod filter, stock bov, 10psi, remap ecu, exhaust
ps- could start maps be crud on the remap?? just an afterthought but problem has been worsening so maybe not :D
https://www.sau.com.au/forums/topic/120472-starting-problems-mostly-hot-start/
I hope this is not your problem but I had a car that did this same thing, turned out to be a hairline crack in a inlet valve housing to water jacket, it only did it when the motor was working, ie if I stopped for awhile it would be ok untill engine reached a certain level (temp didnt move much) it eventually opened enough to fill a cylinder, that shot into the air when I cranked it over lol (no plug motor wouldnt turn over).
Its strange but I just posted that the other day on a topic about non reving motor (cue in twilight zone music)
nooooooooooo............say its not so.....how do i get this tested for??
about a year back the timing belt/water pump was being replaced in a certain Syd imports/skylines workshop and they farked the head by turning it over with no timing belt or something totalling a valve - causing no comp in that cyl
they then sent off the head to be fixed and put her back together, duno if that means anything here but yeh
thnx for ur input Terry
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
