Hey guys,
k over the last few months i have a worsening starting problem in the RB20DET. Battery is cranking it fine and starter too but it just doesnt want to turn it into an idle
Im also experiencing clutch in/braking stalls at lights which is particularly fun when it takes 10 cranks to get it going :D have to heel toe gas to keep alive mostly
cold start - about 1 in 3 cranks it will start
hot start - about 1 in 10 cranks to start the bugger, and both scenarios require throttle to gain a stable idle
I also had a miss a while back but replaced a faulty coil and renewed spark plugs and its now running very strongly and quite smooth.....when it finally gets going that is
other info:
battery new and charged
afm recently cleaned
aac valve cleaned
pretty sure no vaccum leaks
040 fuel pump earthed to chassis (not ecu) as per thread on here
Ive done a bit of research and from what i can gather possible causes of this could be:
leaking injector/s or fuel pressure reg??
faulty coolant temp sensor
ignitor faulty/ overheating
coils again, but there is no miss really and power is good??
Thx for reading would really apprec some input/help/ideas as to why it doesnt want to start properly and stalls now and again!!!!
car has:
rb25 turbo, fmic, pod filter, stock bov, 10psi, remap ecu, exhaust
ps- could start maps be crud on the remap?? just an afterthought but problem has been worsening so maybe not :D
https://www.sau.com.au/forums/topic/120472-starting-problems-mostly-hot-start/
I hope this is not your problem but I had a car that did this same thing, turned out to be a hairline crack in a inlet valve housing to water jacket, it only did it when the motor was working, ie if I stopped for awhile it would be ok untill engine reached a certain level (temp didnt move much) it eventually opened enough to fill a cylinder, that shot into the air when I cranked it over lol (no plug motor wouldnt turn over).
Its strange but I just posted that the other day on a topic about non reving motor (cue in twilight zone music)
nooooooooooo............say its not so.....how do i get this tested for??
about a year back the timing belt/water pump was being replaced in a certain Syd imports/skylines workshop and they farked the head by turning it over with no timing belt or something totalling a valve - causing no comp in that cyl
they then sent off the head to be fixed and put her back together, duno if that means anything here but yeh
thnx for ur input Terry
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
