Hi all,
I'm about to purchase a R34 GTt, which has done about 114,000kms or thereabouts. I'm unsure about the service history, so i thought it'd be safe just to give it a major service.
So where do you guys recommend? I've heard boostworks is alright.. can anyone confirm/deny this?
Also second part of my question... for the major service i've listed things I wanted changed
* Timing belt
* Water pump
* All fluids
* Plugs
Anything else that I might be missing? Brakes I know have been done recently. Can you give me an estimate of what that might cost?
Thank you all very much,
Thanks
boostworx...check 2 c if thers a note on the timing belt area if it was changed...mines jsut clicked over 100k n i looked n it was changed at 57k for some reason.
No worries ... that's one count for boostworks.
cheers mate.
Thanks guys that's pretty good.
Just spoken to shaun from Boostworx. Mentioned that I heard about him from varous car clubs. And he was genuinely helpful.
He's given me the following quote for a major service
$170 water pump
$95 timing belt
$240 labour
$77 service / safety
$65 oil
$140 redline diff + tranny service
$55 coolant
$145 dyno tune
$140 platinum plugs
But would do it for about $1000.
What do you reckon?
Edited by Howie
Well when you add up all those figures it comes to more than $1100...... So it's sounds like a good deal to me!
Ring a couple of others like Tilbrooks and Graham West and compare, I have in the past and Shaun beat them hands down, so all my work goes thru Shaun, even mates of mine!
Okay, even if Tilbrook is about the same price as Boostworks i'd still take it to boostworks. I've had some major work done on my previous ride at Tilly's ... i won't say anymore and leave it as that. :
Thanks for all your input guys, much appreciated.
Edited: spelling.
Edited by Howie
I believe he is generally open on Saturday mornings, Prob until about 12-1ish!
Thanks again. I'll have a chat to him... sounds like Boostworks is to Skyline owners what S&J are to WRX owners.
Yeah boostworx was cheaper than Graham west I was happy with them even with them not being able to fix my car, I will be going back to them later when i need work done.
and cheers Darren for putting me on to them, it especially heplfull having them around the corner from work.
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
