Hi all,
Planning to put some Type B Poncams in very shortly and just going through the instructions that are in Japanese. There is this whole section on a modification that you have to do to the BOV - unfortunately in this case, pictures don't tell a thousand words and I'm quite confused.
Has anyone done this or has any idea what is required?
Any help would be great,
Thanks
Stan
Yes it's to do with stock blow-off valve! :D And it did show instructions to block up "some" hole, not sure which one though.
On the diagram it's very tiny.
I'll try get the pic up sometime soon.
Oh yeah the stock BOV trick. Basically you pull it apart into halves and you'll see a small hole to the left of the piston. Jam a screw or something else to plug it up and then reassemble. Stops it from 'leaking' apparently.
Cheers to everyone who has helped, you've been fantastic, especially to the guys with photos :laugh:
Now, what if I don't have a BOV anymore (completely removed, blanking plate used instead). Does it mean that I don't have to worry about this?
  • 3 years later...
Old thread revival but..
Satanic - do you have the instructions still from Tomei showing this mod.
I have done it and the car feels a lot more responsive. However It doesn't seem the BOV is functioning as it's intended after this mod according to what Ive read
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
