I know most of you are going to think I have too much time on my hands, and now with uni holidays I DO! ;)
Since im waiting to receive my FMIC Kit, I been searching and pondering a method of making a CAI system using a pod that is also legal! I have read 100's of threads on partitions and home made air boxes but not one of them tickled my fancy. So i have put pen to paper (mouse to mouse pad :D) and thought of a very easy, simple yet efficient closed CAI system...
What you guys think??? This should be legal (in NSW) cause the Pod is covered right??
Please feel free to critique :D
Regards,
Sarkis
Edited by QRI05E
https://www.sau.com.au/forums/topic/120495-pod-enclosure-with-cai-design/
  • Replies 100
Posted Images
Your only problem now is getting enough air into that enclosure through that pipe.
I made my own setup similar to yours (without the surrounding - just the cold air intake) from stock intercooler piping. Works well, but I think that if I sealed the pod off completely, then it would have an adverse effect (not enough air getting in).
Maybe come up with a better intake system that will guarantee more air going to the pod.
I'm pretty sure if you went 4" or even 5" it would be more then adequate air supply for the POD... Either way its a MUCH more flowing design then the factory air box... Even use mandrel bends with the intake pipe to allow more flow...
By sealing off the POD in my design, you will prevent any hot air being sucked in therefore your air source is outside the engine bay... not to mention it makes it legal...
Cheers
Edited by QRI05E
yeah, nice theory. my only suggestion would be to leave a decent size hole (or a few smaller holes) at the bottom of the 10" pipe so as it can suck extra air. and being at the bottom it will be less visible to the boys in blue.
Edited by mad082
True... but that means drilling out a whole that is going to be 4" - 5" something I don't really want to do. Why not just utilize the 3" hole that's already there provided you have an aftermarket FMIC.
Thanks Mads... I will defiantly build a CAI after my FMIC install and I think this will be the best design so far... I personally wouldn’t cut a hole on the bottom but rather add an additional intake pipe :D
Cheers
you could get some flexible silicon piping from autobarn for about $20 to use as the additional piping, and just run in down inside the engine bay to the front bar.
i just have a cold air duct coming up from the front bar through the existing smic hole to my pod, but i have it open as well. up here in freezing QLD you don't have to have the pod enclosed, just a fixed mounting bracket.
  QRI05E said:
How much they selling that set up Sydneykid? Where can I buy it from??
Cheers
Sorry I don't remebr how much they cost (not cheap), Pipercross agents are;
Revolution Racegear
592 Whitehorse Rd
Mitcham
Melbourne
Tel: (03) 9873 8700
sales@racegear.com.au
www.revolutionracegear.com.au
Stores throughout Australia.
Fabre
4 Frazer Street
Lakemba
NSW
Australia 2195
Tel: 6129 758 1966
info@fabre.co.au
www.fabre.co.au
:D cheers ;)
for flexible pipe... check out clark rubber - trust me you won't be dissappointed!
i have a CAI setup with the stock airbox on my car - a pipe leading goign from the front of hte car into the airbox... i have put a funnel at the front end to maximise ram air :D
cheers,
Warren
i don't have one up here, but he should have one down there. we don't have many good shops up here, but we do have one of the highest rating autobarn in australia here though, so that helps when it comes to getting parts. they know what they are talking about. the new owner has owned a few skylines and other imports so he has started stocking heaps of bits for them, like intake plenums, turbos and intercoolers.
anyone know where to get a cheap bellmouth like in that pic, i know GCG have them,and HKS make them for thiers turbos, but the cost is ridiculous.
then make up a custom flexi pipe the std location...
i have everything else, just need a bellmouth with a 100mm hole.
K&N sell that setup for about $260, We have had a alluminium metal spinner make some for us to suit a 3" by 6" pod filter. We have had him modify it to suit jap cars with air flow meters. Look good and work very well and are legal. Ill attach some pics of one fitted to a SR20 in a 1200 ute. We sell these for $180.
  Craved said:
i just want the bellmouth thats at the end of the black hose(opposite end to the pod)
There is an old trick for this =
Get a piece of PVC tube with the diameter you want, aheat gun and a funnel
Place the PVC pipe upwards, heat the end with the heat gun and use the funnel to push down on the pipe which now hot, will mould to that shape giving you effectively a bell mouth. Very cheap and from the results, just as effective and apparently makes a big difference!
Or if you wanted to get really tricky you could hunt around and borrow several different funnels and carry out the procedure afew times gradually increasing the funnel size to give you a smooth curve = True bellmouth
hehehe thats a pretty good trick, only thing is that the bellmouth will be visible and i dont think pvc will cut it.. might look into it anyway :D
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
