  • Replies 100
Posted Images
In all honesty is theer any gain noticed with a CAI setup for a pod?
it has the same concept as an intercooler...
turbo heats up the charged air, the cooler it comes in at, the cooler it'll leave, less work for the intercooler .. etc etc
do you really see a pod system creating a Vacuum enough to implode the surrounding box?
if the feed os 80mm or more then you shouldn't see any issue..
plus most people running CAI are running boxes that are far from perfectly sealed anyway..
from the first post, i missed that its made of PVC ... i dont think it'll like the heat too much, plsu how do you propose to join the piping to the funnel etc ..
yeah, heat shield + cold air intake! I agree, a little hot air is better than not enought air, espesially when you have a FMIC and it will be cooled anyway!
cops are pretty soft on mods down here... just hard on dickhead drivers!
i dont believe there is such a thing as not enough hot air
the stock airbox and snorkel will suck in the required amount of air.
if you feel its a restriction then fit a higher flowing filter.
sucking in hot air is a bad thing
Hey guys, pretty intresting to see all different CAI systems but to spent $180 - $250 just on the CAI then + $100 for a decent POD is bit over my budget...
Im going to start researching into different materials that could be used to make my CAI design..
I like the PVC funnel idea... quite creative! would love to hear some moe ideas
Cheers
Exactly Paul! As if a custom 3" CAI with a fully sealed POD enclosure isnt going to give you a much better air flow/suction then the standard box! Of coarse it will...
Edited by QRI05E
Does anyone know the legal side of using a POD in NSW??? is it still a defect if its partitioned/boxed???
Cheers
if it is boxed and they cannot see it, legally it still must be able to pass the EPA sound emmissions test. so induction noise is covered within that.
At the moment it is a defect & $70 fine. There is talk about repeat offenders being punished with a demerit point. If it is modified from standard then it has to be engineered, then technically it is street legal. Depends on the cop, ive seen engineered cars get defected all the same. But id rather spend the money and get the filter enclosed and legal rather than copping a couple of fines and then having to outlay the money. It also surprises me that you would consider putting some rough looking pvc ducting in your car, $17000 plus sports cars and always looking for the cheapest option. pvc piping, $400 intercooler kits, $22 bleed valves, absolutely amazes me.
Thats alright then... you can line the inside of the partition/box with thin foam which will reduce the induction noise.. but i love the sound of a skyline comming onto boost :) lol
Sounds like you are some kind of mechanical engineer or something, suggest you dont post rubbish like this, makes you look stupid.
i personally would rather lose a tiny amount of power due to hot air being sucked in, than lose more power by not sucking enough air. if the cai setup will definately supply enough air then fine but i'd rather be safe then sorry.
Edited by mad082
They run a 4" intake, have you seen the standard intake on a airbox? and its about avoiding $70 fines and defects also. My customers would be pretty pissed if i fitted a pod and then he went out and got defected. What you guys do on your own cars is your business, but dont advise other people incorrectly as it will cost them money.
i personally would rather lose a tiny amount of power due to hot air being sucked in, than lose more power by not sucking enough air. if the cai setup will definately supply enough air then fine but i'd rather be same then sorry.
well everyone should know the rules for their state, so if everyone would like to post up the rulings for the different states so that people who don't know can find out.
i'm in qld and according to the 'hoon' squad up here that pulled me over, all you need for a pod to be legal in qld is a fixed mounting bracket for it.
and something i just thought about is if you have a sealed box with just a pipe coming from the front bar, and that pipe is foward facing and in the open, and if you are driving in heavy rain and following cars then you are going to get an airbox full of water. i'd suggest putting a 5mm hole in the bottom of the airbox to let water drain out. it would have to be a real prick of a cop to book you for it, and if you made it at the back of the box where it can't be seen there is less chance of the cop seeing it.
As Paul said its better to have the pod completely sealed from underbonnet air intake. The pod will suck enough air if it have a single 3inch feed. The second you open it up to underbonnet air there is no point having the cold air feed, it'll start sucking air in through the path of least resistance - i. the holes into the engine bay.
And you'll lose more power from increased air intake temps than from a slight pressure drop from the intake system. I know (at least from working with air compressors) that a 3 degree increase in intake air temp decreases power by about 1%. So it
Cold air intakes are most important at low speeds and when taking off. The faster you are going, the less a cold air intake is needed as more air is forced into the engine bay anyway. And the second you increase speed, the pressure drop across the inlet pipe will decrease due to the air being forced into the intake piping - the ram air effect.
To answer your comment, products such as intercoolers, CAI, bleed valves are all non mechanical and non electrical devices.. How can you justify spending the extra $$$ for the a near identical product that does the same job??? Fair enough the name brands might be bit more appealing in appearance but to compare a CAI costing $50 or spending $300 on a name brand and both do the same job is not logical.. and might i add there is nothing wrong with those $400 FMIC kits and $22 boost controllers..
Cheers
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
