  • Replies 100
Posted Images
  Cillham said:
In all honesty is theer any gain noticed with a CAI setup for a pod?
it has the same concept as an intercooler...
turbo heats up the charged air, the cooler it comes in at, the cooler it'll leave, less work for the intercooler .. etc etc
do you really see a pod system creating a Vacuum enough to implode the surrounding box?
if the feed os 80mm or more then you shouldn't see any issue..
plus most people running CAI are running boxes that are far from perfectly sealed anyway..
from the first post, i missed that its made of PVC ... i dont think it'll like the heat too much, plsu how do you propose to join the piping to the funnel etc ..
yeah, heat shield + cold air intake! I agree, a little hot air is better than not enought air, espesially when you have a FMIC and it will be cooled anyway!
cops are pretty soft on mods down here... just hard on dickhead drivers!
i dont believe there is such a thing as not enough hot air
the stock airbox and snorkel will suck in the required amount of air.
if you feel its a restriction then fit a higher flowing filter.
sucking in hot air is a bad thing
Hey guys, pretty intresting to see all different CAI systems but to spent $180 - $250 just on the CAI then + $100 for a decent POD is bit over my budget...
Im going to start researching into different materials that could be used to make my CAI design..
I like the PVC funnel idea... quite creative! would love to hear some moe ideas
Cheers
Exactly Paul! As if a custom 3" CAI with a fully sealed POD enclosure isnt going to give you a much better air flow/suction then the standard box! Of coarse it will...
Edited by QRI05E
  QRI05E said:
Does anyone know the legal side of using a POD in NSW??? is it still a defect if its partitioned/boxed???
Cheers
if it is boxed and they cannot see it, legally it still must be able to pass the EPA sound emmissions test. so induction noise is covered within that.
At the moment it is a defect & $70 fine. There is talk about repeat offenders being punished with a demerit point. If it is modified from standard then it has to be engineered, then technically it is street legal. Depends on the cop, ive seen engineered cars get defected all the same. But id rather spend the money and get the filter enclosed and legal rather than copping a couple of fines and then having to outlay the money. It also surprises me that you would consider putting some rough looking pvc ducting in your car, $17000 plus sports cars and always looking for the cheapest option. pvc piping, $400 intercooler kits, $22 bleed valves, absolutely amazes me.
  QRI05E said:
Thats alright then... you can line the inside of the partition/box with thin foam which will reduce the induction noise.. but i love the sound of a skyline comming onto boost :) lol
Sounds like you are some kind of mechanical engineer or something, suggest you dont post rubbish like this, makes you look stupid.
i personally would rather lose a tiny amount of power due to hot air being sucked in, than lose more power by not sucking enough air. if the cai setup will definately supply enough air then fine but i'd rather be safe then sorry.
Edited by mad082
They run a 4" intake, have you seen the standard intake on a airbox? and its about avoiding $70 fines and defects also. My customers would be pretty pissed if i fitted a pod and then he went out and got defected. What you guys do on your own cars is your business, but dont advise other people incorrectly as it will cost them money.
  mad082 said:
i personally would rather lose a tiny amount of power due to hot air being sucked in, than lose more power by not sucking enough air. if the cai setup will definately supply enough air then fine but i'd rather be same then sorry.
well everyone should know the rules for their state, so if everyone would like to post up the rulings for the different states so that people who don't know can find out.
i'm in qld and according to the 'hoon' squad up here that pulled me over, all you need for a pod to be legal in qld is a fixed mounting bracket for it.
and something i just thought about is if you have a sealed box with just a pipe coming from the front bar, and that pipe is foward facing and in the open, and if you are driving in heavy rain and following cars then you are going to get an airbox full of water. i'd suggest putting a 5mm hole in the bottom of the airbox to let water drain out. it would have to be a real prick of a cop to book you for it, and if you made it at the back of the box where it can't be seen there is less chance of the cop seeing it.
As Paul said its better to have the pod completely sealed from underbonnet air intake. The pod will suck enough air if it have a single 3inch feed. The second you open it up to underbonnet air there is no point having the cold air feed, it'll start sucking air in through the path of least resistance - i. the holes into the engine bay.
And you'll lose more power from increased air intake temps than from a slight pressure drop from the intake system. I know (at least from working with air compressors) that a 3 degree increase in intake air temp decreases power by about 1%. So it
Cold air intakes are most important at low speeds and when taking off. The faster you are going, the less a cold air intake is needed as more air is forced into the engine bay anyway. And the second you increase speed, the pressure drop across the inlet pipe will decrease due to the air being forced into the intake piping - the ram air effect.
To answer your comment, products such as intercoolers, CAI, bleed valves are all non mechanical and non electrical devices.. How can you justify spending the extra $$$ for the a near identical product that does the same job??? Fair enough the name brands might be bit more appealing in appearance but to compare a CAI costing $50 or spending $300 on a name brand and both do the same job is not logical.. and might i add there is nothing wrong with those $400 FMIC kits and $22 boost controllers..
Cheers
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
