  CATKICKER said:
hey aidan, just to let you know, i just got one about a week ago and paid $25 inc ex post! (i think i was lucky)
try posting in the wanted section if you have not already
yeh posted in every state section and in the wtb
maybe i could borrow yours for the drift day then give it back if i dont get one haha!
that would be tip top! found one on ebay but doesnt end for 2 more days, will wait and see... I might need to get someone who is pretty clued up on turbos to have a quick look at it first cause when spinning it by the exhaust wheel it makes a clipping noise, not when spun by intake... and no noise if you push the exhaust inwards as you spin it, was told it was working fine on car not missing a beat just when removed they discovered this noise.... so hopefully should work fine as is.... or just rip the ex wheel to bits lol
Edited by da_snuff
  arsnik said:
Hey ppl.
soz dont have a r33 elbow would also love one myself though. I have 2 bloody r32 elbows and need a r33 one
so if there is a 2nd one out there then yeh would b apreciated aswell..
cheers nick
hey nick, think i might have found one for ya! and one for myself ;)
will pm you where to find it :P
oh yeh and i always see ure car outside my dads place, near woolworths, and its lookin good these days :)
Edited by da_snuff
  arsnik said:
i think thats the one we need by the sounds of it. its the one that goes from the turbo to the intercooler and i better let da_snuff have that one as i asked 2nd
cheers arsnik
the one i have is the standard cast elbow thats bolts to the back of the turbo (exhaust side) is this what he needs?
cheers toff, was at josh's just before and the car is gettin there, will be tuffffffffff :P
we're gonna hav to put ure name down the side of the car for all the parts uve donated :)
cheers mate
arsnik, if you have any trouble getting one now, ive got heaps of names of people willing to get rid of em haha
aidan
  toffy said:
ive definately got one and im giving it to jp if you still need it :)
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
