I have a exsisting xforce turbo back set up. The dump and front pipe in one is 3 inch. Since im getting a high mount set up, I need new ones fabricated in 3.5inch. Any idea as to how much this will cost? Also the cat is three inch so should i get a larger size too? Im thinking of just hollowing it out instead
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221162
well if your only running 3" after the cat .. i would run 3" before the cat too ...
im running 3" from turbo back, running stainless custom with an xforce muffler..
cost me $1100 including the new cat..
remember hollowing out the cat with induce flames on the overrun etc, and will potentially melt stuff, as well as be very illegal ... big fines and EPA tests etc.
up to you on that bit. i say dont do it
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221197
I had no cat on my rb20det sil-80, i fabbed up a piece of pipe same length at cat with two flanges and put that inbetween, had some mad flames. I kept the full proper unbutchered cat in garage, then when i sold the car i put it back on. I had it intended if i got sent over the pits at qld tpt, before i went i would put cat back on. Cops couldnt see, cause car was too low anyway. That was back in my young silly days hehe.
I hear the metalcats/magic cats are supposed to flow really really well.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2221456
Have the guys using full 3" exhausts dropped them from the dump and seen if there is a power increase at all?
So that they can definately say there is no gain?
hope u got ear muffs when she's on the dyno, that would be bloody loud when she starts to boost!
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2225702
As a general rule, a 3" exhaust is good for 600 engine hp. That equals around 380rwkw.
As for running larger dump pipes. There is absolutely no need in running anything more than a 1/4 inch larger diameter than the turbine wheel anyway. Any of the 600hp turbos out there should have a fairly large turbine wheel and a 3" usually goes straight up. 3.5 inch is just stupid unless you are chasing 400rwkw or more.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2225878
What rule?
I've seen cars aroun d the 330rwkw mark change to a 3.5 or 4" and pickup another 20rwkw and lots of midrange.
380rwkw & 3" is sus
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2226313
Forget about 3 or 3.5 and worry more about the cat + mufflers.
I have a DoLuck 3" cat-back exhaust which has flowed 328awkw without any problems but was so loud and droned so much you could hear me from 2km away.
For a noise reduction quickfix I got a local muffler place to bolt on a quieter muffler. Whilst my exhaust is now quieter it is sooo restrictive that my boost level is all over the place and the engine just doesnt want to rev above about 5000rpm, at a guess i'd say i've lost an easy 50rwkw (I can hear the massive back pressure just on idle).
The DoLuck canon is basically a massive straight through pipe with baffling around the outside (which does... nothing). The quiet muffler has all sorts of baffling channels around the inside channeling the gases all over the place to help reduce noise, but created a massive restriction.
Edited by benm
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2226332
What rule?
My rule.
And that would be the same rule they use to design turbos and rate them accordingly.
A 3 inch exhaust is enough to sufficiently remove gases from an engine producing 600hp....this is roughly of course but is a good general indication of the system you will require.
In most cases the swap to a 3.5inch would see a gain only in the CAT upsize as this is the largest restriction. Unless the people who made the 20rwkw gain aren't running a cat. It would be silly to say 'oh I've got 380rwkw so I should be good for a 3 inch system' Just because your injectors flow at 550cc or 700cc, doesn't mean you run them at 100% because they can flow that. Anything around the 350rwkw mark and you would automatically upgrade to a larger size.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2227571
I can say yes i have tried this and i didnt gain any HP at the wheels but did gain 30 lbs of torque
I run a Single 3" exhuast with a punched cat on my skyline and its fine. Making 400 kws or so with NOS
Exhausts vary on Engine Size,Cams,Turbo Size & amount of boost.
https://www.sau.com.au/forums/topic/120541-300rwkw-with-3/#findComment-2227698
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
