Whats wrong with the one you have?
my car now stalls on idle... im bout to change spark plugs (NGK iridium) but i figure my AFM is dirty... wanted to know how cheap they are.
i know i should clean mine but im reluctant in opening it up...
im actually really pissed off atm... bottomless money pit.
you don't need to "OPEN IT UP" to clean it.
you just need to take it off the car.
unbolt the air box or pod filter.
then undo the hose clamp that holds it on to the intake pipe.
un plug the afm plug.
now get degreaser and spray the inside where the wire is.
hose it out.. (not with high pressure)
dry it out.
plug it all back in.
if it still has problems, then you may need to resolder..
here is the prob I had..and the fix
http://www.skylinesaustralia.com/forums/in...opic=118437&hl=
Edited by GTST
