Hey all...i'm new to this forum
Have found some helpful posts on here already.
Need some advise:
My R33 driver's side mirror wont fold when i hit the switch. Passenger mirror folds fine.
Any ideas what to look for ?
Hoping for an easy fix here :)
https://www.sau.com.au/forums/topic/120567-r33-drivers-side-mirror-doesnt-fold/
Also, why does it say RB20E on my profile there <<< ?
Is that like a newbie rating ?
welcome to the club :) you can change the rb20e in your personal settings from 'my controls' which should be in the toolbar in top right corner (sorta), as for your mirrors im not very mechanicly minded but the guys here are pretty smart they will know wat to do :cheers:
Yes newbie rating, moves through rb20det->rb25de->rb25det etc as you post.
As for the mirror, could be either a wiring fault, fault with motor in the mirror or something preventing the mirror from closing (something jamming it).
Firstly, i'd look and move it manually and see if there is anything stuck there.
Secondly, i'd get someone to press the button while I listened to the mirror to 'hear' if its trying to close.
If you can't hear anything it means either bad wiring or dead motor: Solution: pull it apart and run a multimeter through the wiring (where the motor connects in, just complete the circuit) when pressing the button to see if you get a voltage. If you do, its the motor thats stuffed. If you don't its the wiring and you need to find the break or short.
If you can hear the motor trying to move it either means the mirror is jammed open (something stuck) so you should find out what it is and remove it, or it could mean that the motor is trying to do its job but its somehow burnt out, and you need to get a new one.
Happy troubleshooting.
hi, i've got the same problem as you.. intead of closing it though, mine closes and doesnt open back up again... i dunno what could be causing this as it folds in fine but doesnt fold back out (i've listened and the motor doesnt even try to fold out).. unless theres 2 motors, one for closing and one for opening??
Edited by shaun123
could be the position switch?!? I've never pulled one apart but i'm guessing there would be an end switch which tells it when its in position. If thats stuck in it might not drive as it thinks its already in the correct position.
Edit : Just followed link above, looks handy
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
