OK.
I have just fitted an 040 to my car and powered it vai direct feed from the battery using a relay to trigger the pump to turn on.
The pump is in and working, providing fuel pressure and starting the car. The problem is the pressure. I have a fuel pressure guage that mesures fuel pressure right after the fuel filter. (the silver round thing in the picture at the top left on the line marked fuel supply) My standard pump was providing 38psi. the new bosch 040 is providing well over 100psi!!!!!
OK so that is probably normal right?
I am really worried that the enging is seeing 100psi fuel pressure. I started the car and black unburnt fuel is coming out the exhaust.
If you look the engine photo you will see that the fuel pressure regulator is in the RETURN line going AWAY from the engine. The fuel supply line does not look like it goes to the reg at all. it goes under it somewhere and I think strairgt to the fuel rails.
so it goes fuel supply>fuel rail>injectors>fuel pressure regulator>return to tank.
I am really confused and need help.
are my injectors getting 100psi fo pressure? They are hose and tail injectors and I don't want to even start the car with that kind of pressure.
should be fine, as the excess fuel is directed back to the tank.
if your really that worried, get a quick dyno readout done to check your afrs
I just drove the car and it is running so rich it will not accellerate under boost at all and clouds of black smoke come uot the exhaust. :P
looks like the reg can not cope. Can I put a reg inline just after the fuel filter? will that fix the problem?
Ok, Bit of an update....
When you start the car it stays on 46pis for about 10 seconds and then WHAM~~~~~ in an instant the guage goes to well over 100 psi (off the reading)
so I am thinking the reg can't hold the pressure of the pump and it shits itself.
So I guess I need a new pressure regulator.
Can anyone tell me where the hell I can get on in canberra today?
Cheers!!
The first thing i'd do is check that the return line to the tank isn't blocked. If it isn't move on to step 2
To get that sort of pressure (without a blocked return line) your reg would have to be stuck shut. I have an 044, stock reg and have base pressures below 40psi.
Don't get a reg before checking the return line! Oh yeah, you fuel hose probably wont be too happy with you either at those sort of pressures, partiularly if you haven't replaced it recently.
Thanks BHdave, you were on the money with one thing.
I put the return line in a bucket and started the car. It flowed perfectly for 5 seconds and then nothing. the stopping of flow happend at exactly the same time as the guage went from 50psi to well over 100.
So the reg is just locking shut about 5 seconds after the engine is started.
'd be a bit careful with that sort of high extreme pressure
if one of the lines fails, shit will go bang big time with fuel going everywhere.
off topic, what engine ?
Yep there is no way I am even starting it again till I have replaced the reg. paulr33. The engine is a VG20DET with RB25 hiflowed turbo and methanol injection... and now a bloody rooted fuel reg :D
You've got to be kidding :D
Anyway, what BHdave said, he beat me to it :)
Pressure RISE is due to the reg, or something after it.
Poor pressure before the reg
thanks R31Nismod...
I laugh every time I see your avatar :D
I am thinking one of these sard regs will do the trick. I am not going to buy a malpassi as I have been told they are shit... Do these look genuine? seems like a really cheap price.SARD FPR
Edited by CEF11E
:D it is most amusing. Although it was put there by a certain admin and is most amusing, i think im a victim.
Whats wrong with using another stock reg?
RB25 stock regs are perfect for huge power
Im no VG expert, but i dare say its probably a very similar (if not the same) reg.
I am afraid if i get another stock reg it will do the same thing. Also the reg I have at the moment is twin entry so an rb25 one will need to be teed into.
I have already ordered one of the sard ones for $130. if it sucks I will cut it up into little pieces and set fire to it...
LoL if it sucks man, your car might set it on fire for you :)
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
