my new turbo arrived today, just thought id share my happiness.
its a schwitzer t88 1100hp rated turbo. apparently been flowed even more than a factory one. this thing is a monster, i cant wait for the lag.. haha
i currently have a gt4088r on it, but its rated at 800hp.
hopefully i can break more than that with my setup..
https://www.sau.com.au/forums/topic/120639-t88-time-ladies/
  • Replies 54
well tuned at 540rwhp, i ran 10.98... could have gone faster, i needed more low down power.. boost dropped off between gears.
with my new setup i should get 9s.... HOPEFULLY
with a powerglide.............. no more manual
https://www.sau.com.au/forums/topic/120639-t88-time-ladies/#findComment-2223813
danielson: how did you find the GT4088, and what rear did it have on it? at the moment i have the same turbo with 1.34 rear on my RB30DET and it is surprisingly good, considering it's a drag turbo designed for rotaries. in 2nd gear you get full juice at about 4500rpm which i was astounded at.
https://www.sau.com.au/forums/topic/120639-t88-time-ladies/#findComment-2224708
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
